DDOtoo
#1 Posted : Sunday, January 5, 2014 4:25:30 PM(UTC)
DDOtoo
I have installed Decklink quad and inputs shows as
Decklink video capture
Decklink video capture 2 through to 4
My problem is 2-4 shows input but the first says device is not compatible when I am just using the same camcorder to test all inputs. So now I have three inputs working instead of 4.
Any guidance please.
jkmakela
#2 Posted : Thursday, January 9, 2014 4:36:48 PM(UTC)
jkmakela
I was hoping to build a pc with two decklink quad cards to get 8 sdi inputs. So interested to see if you can get all four to work!
jkmakela
#3 Posted : Thursday, January 9, 2014 4:40:29 PM(UTC)
jkmakela
Are you having loop out from out put connectors? Cam 1 loop out, Cam 2 loop out etc? Is it possible? I understood that vmix can not use the outputs as independent master output, but is quad automatically looping out input signals via those connectors?
Egriswold
#4 Posted : Thursday, January 9, 2014 6:28:34 PM(UTC)
Egriswold
Was thanked: 33 time(s) in 32 post(s)
DDOtoo
#5 Posted : Thursday, January 9, 2014 10:03:44 PM(UTC)
DDOtoo
Yes all four are working well. You may need to disconnect and reconnect all cables when some are not showing and make sure all are set to the right camera resolutions.
jkmakela
#6 Posted : Friday, January 10, 2014 4:02:27 PM(UTC)
jkmakela
That sound good. 8 sdi in is possible. Can you get loop outputs also from inputs? There is 8 bnc connectors in each card.
Similar Topics
Any experienced with vMix and BMD DeckLink Quad 2 (Systems)
by TL68 12/19/2025 8:16:50 PM(UTC)
PCIE Capacity with Decklink Quad 2 (Systems)
by uofm36 9/4/2025 1:47:11 AM(UTC)
vMix output works but input doesnt on Decklink Quad 2 card (General Discussion)
by Bright7 8/12/2025 12:54:34 AM(UTC)
Blackmagic Decklink Quad HDMI returns Unsupported Video Format (Hardware Compatibility)
by wassers 5/23/2025 6:14:11 PM(UTC)
Problem with image capture via Decklink Quad 2 (Hardware Compatibility)
by svetotehnik 9/12/2024 1:06:12 AM(UTC)
Decklink Quad 2 in a Thunderbolt Enclosure (Hardware Compatibility)
by R0ll0verRandy 6/3/2024 2:22:41 AM(UTC)
PTZ Video Camera problem with DeckLink Quad 2 from BlackMagic (General Discussion)
by vinch3ster 12/14/2023 6:04:31 PM(UTC)
Blackmagic Decklink Quad HDMI Recorder give massive delay after adding more than 2 source (Hardware Compatibility)
by khmerbrave 11/20/2023 9:20:21 PM(UTC)
Decklink Quad 2 + Sonnet Echo SE-IIIe compatibility issues (Hardware Compatibility)
by mburel1980 10/21/2023 5:52:27 AM(UTC)
Error when I external camera with card blackmagic decklink quad 2 (General Discussion)
by nhan7457 8/10/2023 2:16:24 AM(UTC)
carte blackmagic DeckLink Quad 2 (General Discussion)
by kriztof 5/31/2023 1:57:02 AM(UTC)
Motherboard for System w/ Blackmagic DeckLink Quad 2 (Systems)
by LTimW 10/25/2022 9:39:11 AM(UTC)
Reference System Ruby - Decklink Quad 2 disconnects (Hardware Compatibility)
by mct 10/4/2022 11:03:10 AM(UTC)
Blackmagic Decklink Quad 2 Embedded Audio Stuttering (Hardware Compatibility)
by jb1206 10/1/2022 1:00:51 AM(UTC)
Decklink Quad2 - Port 8 Error (Hardware Compatibility)
by Conan.Kim 7/4/2022 7:30:20 PM(UTC)
BMD decklink quad HDMI recorder capture card (Hardware Compatibility)
by Cindy Drozda 4/26/2022 9:17:18 AM(UTC)
External, decklink quad 2 (General Discussion)
by MrAzzar 12/17/2021 2:22:21 AM(UTC)
AJA KONA HDMI or Blackmagic Design DeckLink Quad HDMI (Hardware Compatibility)
by Bodo 6/16/2021 10:30:47 PM(UTC)
External render - Decklink Quad 2 (Hardware Compatibility)
by KJPark 5/29/2021 7:30:05 PM(UTC)
Decklink Quad 2 - Questions (Hardware Compatibility)
by Speegs 5/22/2021 7:55:00 AM(UTC)
4 cameras via a decklink quad card a through Thunderbolt 3 (Hardware Compatibility)
by Starchie 1/21/2021 11:21:55 AM(UTC)
More SDI/Aux Video Outputs [DeckLink Quad] (Hardware Compatibility)
by DNatz 11/12/2020 4:37:00 AM(UTC)
Blackmagic Decklink Quad HDMI resolution issues (Hardware Compatibility)
by ejkravetz 10/15/2020 8:22:07 AM(UTC)
Sonnet’s Echo Express SEIII + DeckLink Quad HDMI Recorder (Hardware Compatibility)
by TMClive 5/27/2020 10:01:09 PM(UTC)
Decklink Quad 2 disappeared from the system (Hardware Compatibility)
by SerVag 4/25/2020 11:58:15 PM(UTC)
Using Ultrastudio 4K or Decklink Quad 2, Question (Hardware Compatibility)
by DominicIrving 4/7/2020 6:27:15 AM(UTC)
Decklink Quad 2, 1080p50, source drops *Solved* (Hardware Compatibility)
by SerVag 4/4/2020 11:16:04 PM(UTC)
Alienware Area-51 with DeckLink Quad 2 (Hardware Compatibility)
by JonHall.conp 2/13/2020 11:49:42 PM(UTC)
Accessing Audio Channels 15 & 16 On SDI (Decklink Quad 2 ) (General Discussion)
by Henny 8/30/2019 1:57:11 AM(UTC)
How run Decklink Quad (not 2nd Gen.) (Hardware Compatibility)
by quantum 3/10/2019 8:04:27 PM(UTC)
