Thanks: 7 times Was thanked: 1 time(s) in 1 post(s)
I have installed Decklink quad and inputs shows as
Decklink video capture Decklink video capture 2 through to 4
My problem is 2-4 shows input but the first says device is not compatible when I am just using the same camcorder to test all inputs. So now I have three inputs working instead of 4.
Any guidance please.
Thanks: 2 times Was thanked: 4 time(s) in 4 post(s)
I was hoping to build a pc with two decklink quad cards to get 8 sdi inputs. So interested to see if you can get all four to work!
Are you having loop out from out put connectors? Cam 1 loop out, Cam 2 loop out etc? Is it possible? I understood that vmix can not use the outputs as independent master output, but is quad automatically looping out input signals via those connectors?
Joined: 6/29/2011(UTC) Posts: 316   Location: Florida Thanks: 6 times Was thanked: 35 time(s) in 34 post(s)
jkmakela wrote:I was hoping to build a pc with two decklink quad cards to get 8 sdi inputs. So interested to see if you can get all four to work! Yes all four are working well. You may need to disconnect and reconnect all cables when some are not showing and make sure all are set to the right camera resolutions.
That sound good. 8 sdi in is possible. Can you get loop outputs also from inputs? There is 8 bnc connectors in each card.
