HWL1223
#1 Posted : Wednesday, October 23, 2013 12:07:30 AM(UTC)
HWL1223
I just upgraded from 10 to 11.
My greatest question and concern is - where did my audio mixer go? It is critical for me to be able to jump on the input audio volume controls - FAST. I have no more audio panel.
Unless I am mistaken, it now takes 3 clicks and there is no realtime level control. Am I missing something? Is it a screen resolution issue as I have a smaller portable monitor? (the mixer button needs to be predominant, IMHO)
Please advise - Thanks.
Jup
#2 Posted : Wednesday, October 23, 2013 2:12:36 AM(UTC)
Jup
it's still here in 11 (screen resolution 1280x768):
I just downloaded and installed 11 for a client a few days ago and have been testing it, fades in real time etc.
Edit, you're right. I just downloaded the latest update (11.0.0.34) and the button is gone!
#3 Posted : Wednesday, October 23, 2013 5:17:48 AM(UTC)
Was thanked: 4674 time(s) in 1609 post(s)
vMix requires a minimum resolution of 1280x720 with scaling set to 100%.
You can check the scaling under Control Panel -> Appearance and Personalisation -> Display
Jup
#4 Posted : Wednesday, October 23, 2013 6:23:02 AM(UTC)
Jup
Sorry, I've always had my scaling to 125% and it was working fine with v10
Now that I've switched scaling down to 100% it's showing all controls.
If scaling is set to 125% (where I prefer it) even at 1280x1024 I only get this:
Edit; I just rolled back to v10 and I see that the "external|start" buttons were not visible because of my settings, which didn't bother me because I didn't use those features. That explains everything, thanks.
HWL1223
#5 Posted : Thursday, October 24, 2013 12:43:00 PM(UTC)
HWL1223
Martin;
PLEASE add a hotkey that can launch the audio mixer panel.
I need to grab volume levels and sometimes dont have a large resolution monitor to access that soft button.
Thank you
thanks 1 user thanked HWL1223 for this useful post.
Jup on 10/24/2013(UTC)
HWL1223
#6 Posted : Wednesday, April 9, 2014 3:00:59 PM(UTC)
HWL1223
I still really need this and would appreciate it even if I need to make a custom key. I sometimes do NOT have a monitor on remotes larger than 1024x768 and just need to launch and steer the channel or mains mixers...
Thanks!
HWL wrote:
Martin;
Thank you
Similar Topics
Audio mixer API enhancements (Feature Requests)
by machadofernandoeng 3/7/2025 8:19:39 AM(UTC)
Separate Audio Mixer / Video Switcher Integration (General Discussion)
by BriarPatchMedia 6/26/2024 11:54:45 AM(UTC)
Audio Mixer Pin Icon (Feature Requests)
by Roy Sinclair 2/29/2024 10:43:11 AM(UTC)
Audio Mixer on Vmix (General Discussion)
by Michael7687 2/29/2024 6:55:52 AM(UTC)
Settings to enable/disable "Mouse Wheel for Audio Mixer faders" (Feature Requests)
by mct 2/2/2024 6:42:06 AM(UTC)
Audio Mixer for vMix (Hardware Compatibility)
by fabfab10 10/26/2023 7:13:47 PM(UTC)
Audio Mixer Functionality (Feature Requests)
by daveydouble 4/9/2022 5:59:04 PM(UTC)
Audio Mixer highlight (Feature Requests)
by JohnG 1/10/2022 8:50:11 AM(UTC)
audio mixer separate (General Discussion)
by davidcl 11/24/2021 8:30:47 AM(UTC)
Audio Mixer: use different colors (not just green) per bus (Feature Requests)
by Ario 4/17/2021 4:41:36 AM(UTC)
Audio Mixer number (General Discussion)
by manuelbotto 4/7/2021 7:32:38 PM(UTC)
Make active Solo icon "S" orange in audio mixer, not green (Feature Requests)
by Ario 2/8/2021 7:57:05 AM(UTC)
Audio mixer with vMix input control? (Hardware Compatibility)
by rollfocus 1/9/2021 5:27:08 AM(UTC)
Audio Mixer, show Input Number next to input name & hovers on truncated names (Feature Requests)
by Ario 12/17/2020 7:44:04 AM(UTC)
External audio mixer (General Discussion)
by JEK58 12/7/2020 6:18:27 AM(UTC)
Kinda buggy detached IR, Audio Mixer and List windows (General Discussion)
by Rinsky 12/3/2020 10:49:01 AM(UTC)
Use External Audio Mixer (General Discussion)
by scareacon 8/28/2020 2:05:42 AM(UTC)
MIDI controller Audio Mixer VMiX (General Discussion)
by pratyekmeal6 8/4/2020 3:40:14 AM(UTC)
Urgent: Disappearing Audio Mixer & List Panels during show (General Discussion)
by hotdogl0l 6/23/2020 7:40:16 AM(UTC)
Input Number on Audio Mixer (Feature Requests)
by CHILEvents 6/23/2020 6:42:21 AM(UTC)
Audio Mixer expansion (Feature Requests)
by hmastet 5/30/2020 7:23:51 PM(UTC)
Audio Mixer GUI update (Feature Requests)
by sinc747 5/9/2020 8:14:42 AM(UTC)
Pin/UnPin Audio Mixer (Feature Requests)
by Nick 4/8/2020 6:13:06 AM(UTC)
Control audio mixer channels (General Discussion)
by Marvin 4/7/2020 1:36:56 AM(UTC)
vMix with audio mixer (vMix Call)
by Rick Vogelesang 1/4/2020 2:43:51 AM(UTC)
Audio Mixer Outputs - Inputs labels and color assignments change (Feature Requests)
by Jamiehome2 11/13/2019 8:32:19 AM(UTC)
audio mixer ouputs (General Discussion)
by Jamiehome2 11/13/2019 6:43:57 AM(UTC)
Display Request: Audio Mixer (Feature Requests)
by MarkNF82 11/3/2019 12:41:03 AM(UTC)
Dock/undock Audio Mixer (General Discussion)
by chester 2/28/2019 8:16:11 AM(UTC)
Audio Mixer 'Always on Top'. (Feature Requests)
by NHT 11/25/2018 10:20:56 PM(UTC)
