Joined: 5/26/2013(UTC) Posts: 148  Location: Houston, TX, US Thanks: 28 times Was thanked: 6 time(s) in 6 post(s)
I just upgraded from 10 to 11. My greatest question and concern is - where did my audio mixer go? It is critical for me to be able to jump on the input audio volume controls - FAST. I have no more audio panel. Unless I am mistaken, it now takes 3 clicks and there is no realtime level control. Am I missing something? Is it a screen resolution issue as I have a smaller portable monitor? (the mixer button needs to be predominant, IMHO) Please advise - Thanks.
Thanks: 13 times Was thanked: 3 time(s) in 3 post(s)
it's still here in 11 (screen resolution 1280x768):  I just downloaded and installed 11 for a client a few days ago and have been testing it, fades in real time etc. Edit, you're right. I just downloaded the latest update (11.0.0.34) and the button is gone!
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4798 time(s) in 1647 post(s)
vMix requires a minimum resolution of 1280x720 with scaling set to 100%. You can check the scaling under Control Panel -> Appearance and Personalisation -> Display
Sorry, I've always had my scaling to 125% and it was working fine with v10 Now that I've switched scaling down to 100% it's showing all controls. If scaling is set to 125% (where I prefer it) even at 1280x1024 I only get this:  Edit; I just rolled back to v10 and I see that the "external|start" buttons were not visible because of my settings, which didn't bother me because I didn't use those features. That explains everything, thanks.
Martin; PLEASE add a hotkey that can launch the audio mixer panel. I need to grab volume levels and sometimes dont have a large resolution monitor to access that soft button. Thank you
 1 user thanked HWL1223 for this useful post.
I still really need this and would appreciate it even if I need to make a custom key. I sometimes do NOT have a monitor on remotes larger than 1024x768 and just need to launch and steer the channel or mains mixers... Thanks! HWL wrote:Martin; PLEASE add a hotkey that can launch the audio mixer panel. I need to grab volume levels and sometimes dont have a large resolution monitor to access that soft button. Thank you
