I was setting up skype call by following https://www.vmix.com/kno...h-return-video-and-audioUnfortunately I don't get Step 6 when I Open vMix and go to Add Input -> NDI / Desktop Capture -> NDI. I see my blank desktop and vMix-Output underneath, My question does Skype work for Basic Hd?
@ makuno
Did you have an active Skype call to capture? (if no one is on the other side, Skype has no NDI signal to send)
THanks I got you I had no skype from the other side.
You're better off to enable NDI output in Skype. Then add it as an NDI source, not desktop using capture.
