sebrame
#1 Posted : Tuesday, February 20, 2018 5:56:52 PM(UTC)
sebrame
Sorry for the probably simple question. Transitioning from Wirecast, and trying to figure things out quickly.
I have a program which includes one camera, PowerPoint via NDI, and a few videos. Of course during the camera presentation I'll be switching back and forth to the PowerPoint, and I've figured out how to have my camera's audio stay on when switching, but when I switch to one of the videos, I need for it's audio to be solo, killing the camera's audio til the video ends and I switch back to the camera. Is there a way to have this occur automatically, or am I relegated to manually muting the camera's audio every time I switch to a video?
Thanks!
Steve
guztavo
#2 Posted : Tuesday, February 20, 2018 7:22:32 PM(UTC)
guztavo
Thanks!
Steve
Take a look: https://www.vmix.com/help20/Audio.html
#3 Posted : Tuesday, February 20, 2018 8:51:57 PM(UTC)
@ sebrame
First of all, welcome to the vMix Forums.
As with all things vMix, there are usually several ways to do things.
In your situation, I assume you've enabled the camera audio to be active all the time, in order to turn it OFF when playing a video, you can use a "Trigger" on the video Input:
cog wheel of Video Input -> Triggers tab -> "OnTransitionIN"/AudioOFF/Camera Input -> Add
You'll probably want to turn it back on at some point, which can also be done with a Trigger, either an "OnTransitionOUT" function of the same video Input or an "OnTransitionIN" function on the Camera Input itself. Either one should work but really comes down to your overall workflow requirements. All-in-all, "Triggers" can be very useful but also somewhat convoluted if your set-up is complex (whatever you turn on, will likely have to be turned off and/or vice versa).
A simpler solution is to enable the "Automatically mix Audio" of the Camera Input and simply add it as a MultiView Overlay to the PowerPoint Input and disable its visibility (tic box next to Overlay #). This way, the Camera Audio will always be audible whenever either of those two Inputs is LIVE and OFF when not.
sebrame
#4 Posted : Tuesday, February 27, 2018 8:14:19 PM(UTC)
sebrame
Ha! Just checked on this thread and saw the latest. Looks like I'm not getting emailed notifications of replies.
Anyway, thanks IceStream! Unfortunately, the webcast is over, and I had to play around with it but finally figured it out without using Triggers. But, that sounds like a much better plan, so I'll bone up on that ASAP.
Similar Topics
Extended Audio Mixer View when Unpinned (Feature Requests)
by Anders 5/12/2026 5:24:54 AM(UTC)
Audio mixer API enhancements (Feature Requests)
by machadofernandoeng 3/7/2025 8:19:39 AM(UTC)
Separate Audio Mixer / Video Switcher Integration (General Discussion)
by BriarPatchMedia 6/26/2024 11:54:45 AM(UTC)
Audio Mixer Pin Icon (Feature Requests)
by Roy Sinclair 2/29/2024 10:43:11 AM(UTC)
Audio Mixer on Vmix (General Discussion)
by Michael7687 2/29/2024 6:55:52 AM(UTC)
Settings to enable/disable "Mouse Wheel for Audio Mixer faders" (Feature Requests)
by mct 2/2/2024 6:42:06 AM(UTC)
Audio Mixer for vMix (Hardware Compatibility)
by fabfab10 10/26/2023 7:13:47 PM(UTC)
Issue with Automatic Audio Mixing with Mix-Input (General Discussion)
by floh 7/20/2023 7:39:28 PM(UTC)
Reattach Audio Mix Pallette (General Discussion)
by talkinlive 7/15/2023 2:18:00 AM(UTC)
Audio Mixer Functionality (Feature Requests)
by daveydouble 4/9/2022 5:59:04 PM(UTC)
Audio Mixer highlight (Feature Requests)
by JohnG 1/10/2022 8:50:11 AM(UTC)
audio mixer separate (General Discussion)
by davidcl 11/24/2021 8:30:47 AM(UTC)
Audio mix help (General Discussion)
by Stuart McCafferty 8/29/2021 8:48:05 PM(UTC)
More SRT outputs (for audio mix minus purposes) (Feature Requests)
by carlofornasari 5/11/2021 11:12:22 PM(UTC)
Audio Mixer: use different colors (not just green) per bus (Feature Requests)
by Ario 4/17/2021 4:41:36 AM(UTC)
Audio Mixer number (General Discussion)
by manuelbotto 4/7/2021 7:32:38 PM(UTC)
Make active Solo icon "S" orange in audio mixer, not green (Feature Requests)
by Ario 2/8/2021 7:57:05 AM(UTC)
Audio mixer with vMix input control? (Hardware Compatibility)
by rollfocus 1/9/2021 5:27:08 AM(UTC)
Audio Mixer, show Input Number next to input name & hovers on truncated names (Feature Requests)
by Ario 12/17/2020 7:44:04 AM(UTC)
External audio mixer (General Discussion)
by JEK58 12/7/2020 6:18:27 AM(UTC)
Kinda buggy detached IR, Audio Mixer and List windows (General Discussion)
by Rinsky 12/3/2020 10:49:01 AM(UTC)
Use External Audio Mixer (General Discussion)
by scareacon 8/28/2020 2:05:42 AM(UTC)
MIDI controller Audio Mixer VMiX (General Discussion)
by pratyekmeal6 8/4/2020 3:40:14 AM(UTC)
Urgent: Disappearing Audio Mixer & List Panels during show (General Discussion)
by hotdogl0l 6/23/2020 7:40:16 AM(UTC)
Input Number on Audio Mixer (Feature Requests)
by CHILEvents 6/23/2020 6:42:21 AM(UTC)
Audio Mixer expansion (Feature Requests)
by hmastet 5/30/2020 7:23:51 PM(UTC)
VMix Call Auto Audio Mix/ Audio Buses (vMix Call)
by TomCP 5/20/2020 3:52:40 PM(UTC)
Audio Mixer GUI update (Feature Requests)
by sinc747 5/9/2020 8:14:42 AM(UTC)
Pin/UnPin Audio Mixer (Feature Requests)
by Nick 4/8/2020 6:13:06 AM(UTC)
Control audio mixer channels (General Discussion)
by Marvin 4/7/2020 1:36:56 AM(UTC)
