PTZ
spencerm24
#1 Posted : Saturday, January 20, 2018 5:24:58 PM(UTC)
spencerm24
Was hoping this was in a search on here but seems to not be (or I suck at searching, either one is likely true!)
I have a joystick for my PTZ camera, and have configured the move left/right/up/down and zoom in/out command. It seems to be lacking some features I either cannot figure out, or dont exist
-Ability to control speed by the joystick itself, either through a button for slow "on air" moves, that when not held, it defaults to the normal speed of "make me dizzy"
-Ability to control the active camera the joystick controls. I have a bank of 6 buttons on mine, and I'd like that to select which PTZ cam it is currently controlling.
Are any of these possible?
thanks 1 user thanked spencerm24 for this useful post.
Torg on 5/8/2019(UTC)
raugert
#2 Posted : Sunday, January 21, 2018 2:28:48 AM(UTC)
raugert
Canada
Was thanked: 322 time(s) in 184 post(s)
What model of PTZ camera and what kind of controller are you using?
spencerm24
#3 Posted : Tuesday, January 23, 2018 10:46:42 AM(UTC)
spencerm24
Camera is the Panasonic aw-he70
Controller is a Logitech Joystick 3D Extreme Pro.
raugert
#4 Posted : Wednesday, January 24, 2018 12:12:12 AM(UTC)
raugert
Canada
It appears that the joystick is not a true midi controller as such. However I found an interface program that allows you to program the buttons into midi commands. http://little-scale.blog...pro-analog-joystick.html
With this interface you should be able to program the midi shortcuts in vMix accordingly. I’m not 100% sure if this will work but it’s just a thought. Maybe you are already doing something like this ?
richardgatarski
#5 Posted : Wednesday, January 24, 2018 4:18:03 AM(UTC)
richardgatarski
Was thanked: 299 time(s) in 251 post(s)
spencerm24,
You might want to take a look att the PTZ camera control software from Rocosoft, I believe you can get a free trial version.
/richard
ps please try to be a little bit more descriptive in tha Topic's name, "PTZ" is very general. Makes it easier for us to assess if we can help a fellow vMixer. Thanks.
spencerm24
#6 Posted : Wednesday, January 24, 2018 10:14:54 AM(UTC)
spencerm24
richardgatarski wrote:
spencerm24,
/richard
That would work, but I have a joystick already. I'm looking for a way to control the speed of the camera movement. Even as simple as a toggle button to go from slow to fast (on air move vs off air move) seems vmix only has "move" commands, not variable speed of the move. I can set the speed of the move command but that is locked and not variable.
Also, It seems I can only control one single input with the joystick, which makes it a major pain to control multiple PTZ cameras. I can't believe there's no option to select "CAM 1 is active for control" or "CAM 2 is active for control" The Logitech joystick and the XKeys joystick have buttons associated with them, so they can be used for "active control" toggle for the variable cameras.
richardgatarski
#7 Posted : Wednesday, January 24, 2018 12:22:10 PM(UTC)
richardgatarski
Rocosoft is software, that works with many Joysticks including yours (I am pretty sure of). It is far more flexible than vMix's PTZ control. And if I remember correctly from our test (6 months ago) one can assign button on the Joystick that selects wich camera to control. I think we even assigned Joystick buttons to vMix shortcuts. One way for you to explore this is to download a trial version and do some experiments.
spencerm24
#8 Posted : Wednesday, January 24, 2018 1:57:49 PM(UTC)
spencerm24
I will be downloading the trial and seeing how it works. Thanks.
rowby
#9 Posted : Wednesday, January 24, 2018 2:59:16 PM(UTC)
rowby
Hi
See my thread about something similar here: https://forums.vmix.com/...aspx?g=posts&t=11392
Rowby
spencerm24
#10 Posted: : Wednesday, January 24, 2018 3:28:45 PM(UTC)
spencerm24
Thanks, after reading that thread, it seems like variable speed control based on input pressure for the joystick is not possible at this time, I'd like to at least be able to mimic a dedicated controller for PTZ cameras, the one I have for mine that I was hoping to replace by integrating into vMix lets me gently pan if I just slightly touch the joystick, or fast pan if I crank it to one side, but seems vMix is binary, GO or STOP speeds with panning. I am waiting for the trial licence for Rocosoft's software mentioned here, to see if that works, but if not, I'll have to stick with the OEM Panasonic controller.
Video Dave
#11 Posted : Wednesday, January 24, 2018 6:10:17 PM(UTC)
Video Dave
spencerm24, just curious, are you using R232 VISCA control or VISCA over IP?
I use a Logitech Wireless Gamepad and programmed the buttons to select which cam I want to control.
spencerm24
#12 Posted : Friday, January 26, 2018 10:02:54 AM(UTC)
spencerm24
I believe it is over IP, in vMix I connect via the IP Address.
rowby
#13 Posted : Friday, January 26, 2018 11:32:03 AM(UTC)
rowby
Hi Spencer
Looking forward to seeing your updates to your testing of a variable solution.
Rowby
spencerm24
#14 Posted : Friday, January 26, 2018 11:58:47 AM(UTC)
spencerm24
rowby wrote:
Hi Spencer
Rowby
Best solution I have so far, is to use NDI, install the Newtek NDI software which has a built in PTZ Controller in the NDI Monitor. It is much smoother than the vMix controls. Its not perfect, but significantly better than native vMix controls. Only thing I'm not sure about now is how to change that to control more than 1 camera via buttons on the joystick through the NDI Monitor. in vMix it seems you'd put it on preview and set the PTZ control to preview, not sure yet how the NDI Monitor software would do this.
Similar Topics
PTZ Positioning Buttons - an annoyance (Feature Requests)
by BroadKast 12/17/2025 3:38:07 AM(UTC)
smartPTZ, SRT/PTZ app for iPhone, Built with vMix in Mind! (3rd Party Software and Development)
by Troyhanford 11/12/2025 7:27:54 AM(UTC)
PTZ programmed movement in loop (Feature Requests)
by stefan svanstrom 10/30/2025 7:34:09 AM(UTC)
PTZ Position and different speed of positioning based on the saved preset (General Discussion)
by itarsc3 7/24/2025 2:07:12 AM(UTC)
PTZOptics Cameras Freeze over NDI (NDI)
by fcd 7/23/2025 4:07:59 AM(UTC)
Ptz loop movement (Feature Requests)
by stefan svanstrom 6/26/2025 7:58:15 PM(UTC)
Shorcut: Visca PTZ Autoframing start/stop (Feature Requests)
by blackburst 6/25/2025 12:17:26 PM(UTC)
PTZ Popout (Feature Requests)
by hphunt 6/20/2025 11:58:59 AM(UTC)
Obsbot UVC PTZ does not Pan (Hardware Compatibility)
by AlanZ 5/7/2025 1:41:12 AM(UTC)
AVKANS 30x NDI camera and PTZ (General Discussion)
by stpaulsmilaca 3/5/2025 4:00:09 AM(UTC)
Referece system for 20 NDI PTZ Cameras 2K @ 60 FPS (Systems)
by Bulldog 2/20/2025 9:33:26 AM(UTC)
PTZ camera suddenly not connecting (Hardware Compatibility)
by KHartman 2/16/2025 3:39:04 AM(UTC)
PTZ Tracking (Feature Requests)
Belarus hadphild 1/29/2025 3:25:43 AM(UTC)
Merge anomalies with Flattened Layers, PTZ and Layers (Beta Discussion)
by Highway20Productions 1/16/2025 3:42:06 AM(UTC)
Help Needed with SMTAV IP PTZ Cameras Positioning Issue (Hardware Compatibility)
by jacan sevada 1/13/2025 12:14:50 PM(UTC)
PTZ panassonic aw-ue50 (Hardware Compatibility)
by junior duarte 12/13/2024 10:50:40 PM(UTC)
PTZ camera not moving between presets (General Discussion)
by KHartman 12/11/2024 11:13:10 PM(UTC)
Script or shortcut for PTZ Connect toggle (General Discussion)
by MSFTGuruGuy 11/11/2024 11:20:48 AM(UTC)
Floating PTZ Camera Controls Panel (Feature Requests)
by jasonfromaustin 11/1/2024 4:29:33 AM(UTC)
Prevent Accidental Virtual PTZ movement while camera is in program. (Feature Requests)
by jeregan 10/30/2024 4:07:15 AM(UTC)
NDI as a selection in PTZ connection options (Feature Requests)
by mavik 5/24/2024 4:26:47 AM(UTC)
Panasonic AG-CX350 over NDI PTZ (General Discussion)
by mavik 5/23/2024 12:42:12 AM(UTC)
2 or more NDI PTZ cameras (General Discussion)
by kabachin 5/9/2024 9:44:14 PM(UTC)
RTSP VIA Ethernet for JVC PTZ KY-PZ100BU (General Discussion)
by tborland1 3/12/2024 5:49:29 AM(UTC)
Ptz controller in vmix (General Discussion)
by LAEM77 2/24/2024 6:43:53 AM(UTC)
Virtual PTZ control with Birddog P4K problems (Hardware Compatibility)
by Sacha Goodwin 2/22/2024 10:16:24 PM(UTC)
Zoom PTZ control (Feature Requests)
by fgolman 2/12/2024 12:48:00 AM(UTC)
PTZ control over NDI / Kiloview encoder (NDI)
by ckvideo 1/9/2024 11:35:44 PM(UTC)
Issue with Create Input At This Position for PTZ cameras (General Discussion)
by TheBB 12/28/2023 6:12:18 AM(UTC)
PTZ Video Camera problem with DeckLink Quad 2 from BlackMagic (General Discussion)
by vinch3ster 12/14/2023 6:04:31 PM(UTC)
