PTZ camera not moving between presets
The computer at church decided it no longer wanted to work so we had to buy a new computer that I am now setting up again to livestream our services. Everything worked just fine on the old computer and now I’m having issues with the cameras. I have just started setting up the camera angles and 1 camera has 2 different angles set up (for the moment). I tested the cameras to see how it was working and the camera will not switch between the 2 angles. The presets I have are “Pulpit”, “Lecturn”, and “Congregation”. I cannot switch between the pulpit and the lecturn. I tried switching between pulpit and congregation and then lecturn and I doesn’t move the camera to the lecturn. I have the newest version of VMix and am attempting to update the firmware of the cameras but have a ticket in for that. If the firmware will fix it then no worries, I’ll get that fixed. I just wanted to see what y’all thought could be going on.
Thanks: 64 times Was thanked: 160 time(s) in 144 post(s)
It is not clear to me where the problems start. Have you just opened the old preset on the new computer? You will probably have to create new PTZ inputs. Is the camera connected on the PTZ tab of the camera input?
