PTZ functions showing as "const_xxx" in vMix 28 (worked correctly in vMix 24)
Joined: 5/28/2023(UTC) Posts: 1  Location: Colombia Thanks: 1 times
Hi everyone, I'm experiencing an issue with PTZ shortcut functions in vMix and wanted to check if anyone else has encountered this. I use PTZ shortcuts mapped to an Xbox controller for camera control. In **vMix version 24.0.0.72**, all PTZ functions appear correctly in the shortcut list (Move, Zoom, Focus, Stop, etc.), and everything works as expected. However, in **vMix version 28.0.0.42**, many of these functions do not appear correctly and instead show up as: const_647 const_650 const_653 const_655 const_656 ...and others. Because of this, it's impossible to clearly identify which function is being assigned, which essentially breaks my workflow. ### What I’ve tried: * Restarting vMix * Creating a new preset * Reinstalling vMix * Checking specifically the PTZ category ### Expected behavior: All PTZ functions should appear with their proper names (as in vMix 24), not as internal "const_xxx" values. ### Questions: Is this a known bug in vMix 28? Is there any fix, workaround, or update that resolves this? Thanks in advance for any help.  Captura de pantalla 2026-03-20 205023.png (14kb) downloaded 28 time(s). Captura de pantalla 2026-03-20 204030.png (36kb) downloaded 28 time(s).Image 1: vMix 24 (correct PTZ functions) Image 2: vMix 28 (functions showing as const_xxx)
Joined: 1/13/2010(UTC) Posts: 5,373  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
Most likely a pirated copy of vMix as this is simply not possible with an authorised copy. You can reach out to vMix Support directly to verify this: https://www.vmix.com/contact-us.aspx
