Diego Salcedo
#1 Posted : Saturday, March 21, 2026 12:40:07 PM(UTC)
Diego Salcedo
Colombia
I'm experiencing an issue with PTZ shortcut functions in vMix and wanted to check if anyone else has encountered this.
I use PTZ shortcuts mapped to an Xbox controller for camera control.
In **vMix version 24.0.0.72**, all PTZ functions appear correctly in the shortcut list (Move, Zoom, Focus, Stop, etc.), and everything works as expected.
However, in **vMix version 28.0.0.42**, many of these functions do not appear correctly and instead show up as:
const_647
const_650
const_653
const_655
const_656
...and others.
Because of this, it's impossible to clearly identify which function is being assigned, which essentially breaks my workflow.
### What I’ve tried:
* Restarting vMix
* Creating a new preset
* Reinstalling vMix
* Checking specifically the PTZ category
### Expected behavior:
All PTZ functions should appear with their proper names (as in vMix 24), not as internal "const_xxx" values.
### Questions:
Is this a known bug in vMix 28?
Is there any fix, workaround, or update that resolves this?
Thanks in advance for any help.
Captura de pantalla 2026-03-20 205023.png (14kb) downloaded 28 time(s). Captura de pantalla 2026-03-20 204030.png (36kb) downloaded 28 time(s).
Image 1: vMix 24 (correct PTZ functions)
Image 2: vMix 28 (functions showing as const_xxx)
#2 Posted : Saturday, March 21, 2026 5:29:21 PM(UTC)
Most likely a pirated copy of vMix as this is simply not possible with an authorised copy.
You can reach out to vMix Support directly to verify this:
https://www.vmix.com/contact-us.aspx
Diego Salcedo on 3/21/2026(UTC)
