Hi All.
I have a Decklink 4K extreme.
I'm using vmix in a live setting where program audio from a mixer goes into the decklink. It is configured with video output going to an external monitor/display. There is a single SDI input that comes from another switcher.
The only time I need audio out of vmix is when I play a video file. Depending on the occasion, I could have a lot of video files. Otherwise, the audio mixer takes care of audio in the house.
The audio will pass out of the decklink when the external button is not activated. When external is activated, it cuts the audio output.
Any suggestions? Thanks.
Just to summarize...
Audio out from a mixer is going into decklink xlr's Decklink audio out (xlr) coming back to mixer.
External button not pressed = audio passing through and coming back to mixer. ...including audio from video files.
Pressing external button cuts all audio out of the decklink.
Trial and error.... finally got it!
In External Output, I set the following: Audio Channels: BusA
In Audio Outputs, I set the following:
Master Output: None A: Enabled
And It works exactly like I need..
