chaitu
#1 Posted : Tuesday, July 25, 2017 7:44:43 AM(UTC)
chaitu
Hi....I'm new to this forum...
I'm using vMix 17 on Windows 8.1 system. can I use Desktop Capture of vr 18 or 19 with the vMix 17????
the system I'm running the desktop capture is also windows 8.1.
Actually I tried to capture but it is showing the blank screen
#2 Posted : Tuesday, July 25, 2017 10:56:45 AM(UTC)
@ chaitu
This is an interesting question that I am curious to know the actual answer to, as my belief is that NDI is backwards compatible and so even if your vMix 17 has the original release of NDI, my expectation is that it should still work with newer versions.
The fact that it is showing a blank screen is encouraging to me, have you gone through the possible causes as described in the knowledge base?
Here:
http://www.vmix.com/know...gnosing-blank-ndi-inputs
chaitu
#3 Posted : Tuesday, July 25, 2017 12:05:20 PM(UTC)
chaitu
Thanku Ice Stream, for responding.... I have checked the firewall vmix desktop capture is allowed.
While selecting the option in vMix like in inputs>NDI/Desktop Capture there it is showing options like Display 1, other windows,.... After selecting Display1 and clicking Ok. Then it is showing the Blank screen......
#4 Posted : Tuesday, July 25, 2017 12:21:35 PM(UTC)
@ chaitu
Are you capturing "NDI" or "Local Desktop Capture" over a gigabite network switch ?
Have you tried installing NewTek Connect on the other system?
http://pages.newtek.com/NDI-Connect-Download.html
chaitu on 7/28/2017(UTC)
#5 Posted : Tuesday, July 25, 2017 12:48:53 PM(UTC)
Hi
did you try to use NDI Scan Converter instead of vMix Desktop Capture?
Testing this can help solving the issue
https://www.newtek.com/ndi/applications/
Guillaume
Similar Topics
vMix Desktop Capture - from vMix Install vs DL from vmix.com (General Discussion)
by sinc747 2/6/2026 7:16:11 AM(UTC)
Vmix 4k with Desktop Capture over Zoom (General Discussion)
by JohnUK 10/8/2025 12:31:50 AM(UTC)
Desktop Capture for vMix (NDI)
by masaru 9/24/2025 5:00:57 PM(UTC)
Sudden stop of Desktop capture (NDI)
by Covenant 9/8/2025 6:29:57 AM(UTC)
Reconnect Desktop Capture automatically (NDI)
by Bruce27 8/6/2025 6:41:52 AM(UTC)
Desktop Capture from a tablet (General Discussion)
by Gerrit Grobler 4/23/2025 2:07:30 AM(UTC)
vMix Desktop Capture Windows rights level? (NDI)
by nethfel 3/9/2025 2:52:17 AM(UTC)
vMix Desktop Capture for Ultra-wide Screens (General Discussion)
by Jamin 12/24/2024 3:57:38 AM(UTC)
Lag while using local desktop capture (General Discussion)
by Chihiro 12/23/2024 7:19:52 PM(UTC)
Desktop Capture for NDI 27.0.0.3 Issue (NDI)
by hmimura 12/1/2024 6:38:28 AM(UTC)
Desktop Capture shows black screen (NDI)
by cjmccoll 3/9/2024 7:00:17 PM(UTC)
Desktop Capture Shortcuts (Feature Requests)
by jsjoen7896 12/20/2023 2:34:11 PM(UTC)
vMix Desktop Capture NDI - Cannot resize (NDI)
by sjcaldwell 10/14/2023 4:14:38 AM(UTC)
Instant Replay using Local Desktop Capture (General Discussion)
by tgsteveo 10/13/2023 7:20:43 AM(UTC)
Local Desktop Capture Behaves Unexpectedly (General Discussion)
by tomthinks 8/11/2023 8:09:15 AM(UTC)
Mac desktop capture Developer Tools Access? (General Discussion)
by fatlip11 4/21/2023 5:59:39 AM(UTC)
Desktop Capture for Mac: Update? (NDI)
by DVE 3/10/2023 9:09:23 AM(UTC)
two-thirds local desktop capture Problem (NDI)
by coop 2/7/2023 11:44:59 PM(UTC)
Local Desktop Capture showing half of display and entire other smaller display (General Discussion)
by jonnybuttons 12/22/2022 9:57:39 AM(UTC)
Desktop capture/random skips to vmix laptop (NDI)
by _G3_ 12/20/2022 6:55:01 AM(UTC)
vMix Desktop Capture Crashes on Ventura on M1 Mac (NDI)
by BrentCavanagh 11/9/2022 3:45:55 AM(UTC)
vMix Desktop Capture (NDI)
by pesi 10/16/2022 9:12:12 AM(UTC)
desktop capture copartable with vmix 24 (Hardware Compatibility)
by emails4daniel 7/14/2022 5:25:56 AM(UTC)
Desktop Capture For Mac (NDI)
by Beloved 5/19/2022 1:26:48 AM(UTC)
How do I gain the highest resolution from desktop capture when using Chrome and Powerpoint? (General Discussion)
by Ken Robinson 3/30/2022 8:24:11 PM(UTC)
How to gain the highest resolution from desktop capture when using Chrome and Powerpoint (NDI)
by Ken Robinson 3/30/2022 5:56:23 PM(UTC)
vMix Desktop Capture with Win 11 (General Discussion)
by Browntown 3/30/2022 1:36:25 AM(UTC)
Desktop Capture "stutter" (General Discussion)
by whalerfan 2/16/2022 3:47:29 AM(UTC)
Desktop Capture with Keynote Presenter View? (NDI)
by revjgc 2/14/2022 5:54:14 AM(UTC)
NDI Desktop capture not working after Windows upgrade (NDI)
by Tech Support 2/9/2022 4:17:09 AM(UTC)
