STADIORADIO
#1 Posted : Thursday, February 16, 2017 5:16:17 PM(UTC)
STADIORADIO
good evening
Which monitor would be more suitable for Vmix? I mean how big?
#2 Posted : Thursday, February 16, 2017 5:30:50 PM(UTC)
It depends on what you need and how you use it.
I always use FullHD monitors to see everything at full size but I have lightweight 22" monitors for on site production and bigger ones in my lab. I also use 32" TV monitors mainly for multiview on production and 42" models in the lab...
It depends whether you need to carry (and protect) them in a truck or a small car for example.
If you use only 1 monitor for vMix, a bigger one like a 27" is more convenient (the inputs are larger, you see better) but if you use 2 or 3 monitors, they can be smaller I guess like 21/22".
There is no magic answer, it's to you to evaluate the pros and the cons depending on your use cases.
Guillaume
Ittaidv
#3 Posted : Thursday, February 16, 2017 7:22:12 PM(UTC)
Ittaidv
we bought some cheap 21 inch monitors (97%srgb, cheap ips) and removed their stands. This way they fit in a small flightcase. If they break it's not a big deal. In stead of the monitor stands, we use cheap guitar stands to support the monitors on the table, which fold down easily. We use them for fast jobs, where we know the camera's because we own them, and use color presets on them. Since we know our presets (we already did 400+ jobs with some cams) color accuracy is not so important anymore.
Here is a pic of the setup with the guitar stands: https://www.instagram.com/p/6H2ylmMmH1/
The particular model is: JS-AG75 from jamstands. You can buy them on amazon, but I think we paid them cheaper. They fold down to something you can put in a small peli case where you would typically store some cables, and it looks pro on the desk. Additional positive point: we always set up our power distribution box inside those stands.
If we have bigger productions, we take some mid range 24 inch Eizo's to the job. That's necessary because they are 100%srgb. Properly calibrated they're not far off from a rental proper 'tv monitor' which costs 10x the price. They do have stands, since we also use them in our office for editing and take a lot of space in the van. Finding a suitable case is also a problem, so we use the cardboard factory boxes untill we find a better solution.
For the best image quality and color accuracy, I learned that you better invest in proper calibration tools (spyder) and use the rest of your budget for the monitors. I calibrate our monitors monthly, and have the spyder always in a toolcase. A properly calibrated cheap monitor is still better to judge your image on, then an expensive one with the wrong settings.
For size: we always use dual or triple HD monitors. We once tried a bigger monitor (27 inch) and it's more convenient to work with, but it's too bulky for fast deployment in our opinion.
Fast job: 2x cheap monitor
Important job: 2 cheap monitors (for gui and multiview) + 1 eizo (fullscreen program).
Very important job: 2x cheap monitor + 1 eizo + rental professional monitor.
For us size and weight are important factors: our gear + crew needs to fit in our Fiat Doblo at the end of the production. That's why we don't buy big or heavy material. Time to unpack everything, drag it to the workplace and into your storage is also valuable. So in my opinion: smaller is better.
STADIORADIO
#4 Posted : Friday, February 17, 2017 8:30:37 AM(UTC)
STADIORADIO
which monitor may contain two input files with "INSTANT REPLAY" positioned below
Similar Topics
Remote Control for BirdDog Play & NDI Studio Monitor (iOS & Android) (NDI)
by youcci 2/18/2026 8:32:04 PM(UTC)
BMD 3G Monitor Audio Drift (Hardware Compatibility)
by ChrisboBMMS 2/8/2026 11:30:06 AM(UTC)
Possible Audio Monitoring Bug with Zoom Plugin after Updating to vMix 29 (General Discussion)
by xerud 11/7/2025 1:11:01 AM(UTC)
Issue with audio monitoring and mic in Teams (General Discussion)
by codeman3333 6/18/2025 7:35:45 AM(UTC)
Multiview on Fullscreen Monitor stuttering / lagging (General Discussion)
by streaming---pro 4/8/2025 1:10:52 AM(UTC)
Waveform Monitors (PLEASE) (Feature Requests)
by sackboydad 2/23/2025 2:36:23 AM(UTC)
Low Latency Monitor (General Discussion)
by Leapin 2/8/2025 6:42:23 AM(UTC)
Fullscreen monitor choices should match how many monitors are on the system. Not limit to 4. (Feature Requests)
by Highway20Productions 11/12/2024 10:39:44 AM(UTC)
Other external Devices Besides Blackmagic ultrastudio monitor (Hardware Compatibility)
by kaduramos 6/13/2024 3:37:35 AM(UTC)
Waveform monitor outside of input setup (General Discussion)
Belarus sackboydad 4/1/2024 6:21:25 AM(UTC)
Help Please! NDI Desk Capture - Monitor takes over (NDI)
by bdrady 3/15/2024 11:28:38 AM(UTC)
Kiloview E1 NDIHX encoder not seen by vMix or Studio Monitor (NDI)
by DMack 2/13/2024 6:57:29 AM(UTC)
accsoon iphone monitor with vmixcall (vMix Call)
by h2video.nl 2/4/2024 8:23:15 AM(UTC)
Bible Show Monitor and Preview Window (NDI)
by Yemi Kehinde 12/30/2023 12:57:29 PM(UTC)
Actively Monitoring the State of all Scripts in a Preset (General Discussion)
Belarus Video-Chopper 11/15/2023 10:10:24 AM(UTC)
Headphone (Monitor) to Outputs (Feature Requests)
by stevespaw 10/26/2023 1:14:21 AM(UTC)
Assign Headphone (Monitor) to an Output (Beta Discussion)
by stevespaw 10/25/2023 2:39:57 AM(UTC)
vmix 27 to add a Separate Command Line Window to monitor Scripts (Feature Requests)
by WatsonPrunier 10/1/2023 5:41:27 AM(UTC)
Trouble Desktop Capturing a DisplayLink Monitor (General Discussion)
by mgrayeb 7/10/2023 1:57:45 AM(UTC)
VMix Call - How to monitor host audio (General Discussion)
by talkinlive 7/8/2023 2:12:13 AM(UTC)
Host Monitor Feed Full Screen (General Discussion)
by talkinlive 7/8/2023 2:08:19 AM(UTC)
Headphone monitoring while outputting to HDMI (General Discussion)
by DesktopJ 5/28/2023 2:39:45 AM(UTC)
Monitor #s and Fullscreen outputs (Feature Requests)
by obcocav 5/24/2023 8:54:35 PM(UTC)
Laptop, w/Ext monitor set to Duplicate -> Fullscreen blocks main control screen (General Discussion)
by FoolOnTheHill 5/15/2023 7:13:12 AM(UTC)
I would like to be able to divide the layout of the vmix system on a separate monitor. (Feature Requests)
by ywjsys04 5/9/2023 1:33:06 AM(UTC)
Blackmagic Design DeckLink Mini Monitor 4K Black compatible for main output ? (Hardware Compatibility)
by kinpari 5/7/2023 9:23:24 PM(UTC)
Split vMix on Multiple monitors (General Discussion)
by Simsyuk 5/1/2023 4:28:24 AM(UTC)
When a keyboard and a monitor love each other very, very much... (Feature Requests)
by Brett 4/4/2023 6:32:54 PM(UTC)
Help with output a webcam to 1 monitor and livestream simultaneously (General Discussion)
by pancakedelight 3/17/2023 8:59:39 PM(UTC)
[SOLVED] Choose which monitor the "Fullscreen" button goes to (General Discussion)
by TobiBats 3/10/2023 1:28:12 AM(UTC)
