GeorgeR
#1 Posted : Monday, February 22, 2016 2:37:16 AM(UTC)
GeorgeR
Was thanked: 30 time(s) in 28 post(s)
jabin123 wrote:
how do i make xmix be able to hear my skype friends so people in twitch can hear them
jabin123,
Assuming you are using 1 computer you will find information about setting up in the vMix forum here http://forums.vmix.com/default.aspx?g=posts&m=11167#post11167.
If you have 2 computers this is an alternative:
Note: With the upcoming vMix 17 which will include NewTek's NDI (Network Device Interface) including Skype calls might be a lot easier?
This is based on using vMix 16.
1. 2-computers or laptops. One Windows computer for vMix. The Skype computer can be a Windows or MAC.
2. A audio mixer to you vMix computer.
3. vMix (http://www.vmix.com/)
4. vMix desktop capture app. Two apps; install on each computer (http://www.vmix.com/software/download.aspx)
5. Set you Skype call as you normally would. Camera (or webcam) and use some kind of mic on the Skype computer (Windows or MAC) so you caller can hear you.
6. Run an audio patch cord from the headphone jack in the Skype computer to an mic import in your mixer.
7. Start vMix in the Windows computer.
8. Set the audio level for you from the mixer in vMix
9. Set the audio level from the Skype computer in your mixer also.
9. Start the desktop capture in both computers.
10. In vMix, import the Skype computer via the desktop capture app. DO NOT INCLUDE THE AUDIO FROM THE SKYPE COMPUTER VIA DESKTOP CAPTURE.
That should be about all you need to do.
~George
thanks 1 user thanked GeorgeR for this useful post.
Squier on 2/22/2016(UTC)
corporatejames
#2 Posted : Tuesday, February 23, 2016 1:59:20 AM(UTC)
corporatejames
Hi Guys
You can also use Virtual Audio Cable from this company http://vb-audio.pagesper...range.fr/Cable/index.htm
more professional then the suggested virtual cable.
Plus its free. Took me a little while to get used to the setup with which one to select to for output and input.
Regards
James
Similar Topics
I need a VMIX pro to help me via ZOOM (General Discussion)
by curiousgeorge 8/13/2026 7:34:22 AM(UTC)
Need help with URL Input keyboard input, Please help asap (General Discussion)
by knbPixels 5/9/2026 12:16:30 AM(UTC)
Data Source/Scripting Help (General Discussion)
by AndrewH 4/9/2026 2:13:15 PM(UTC)
Help with adding RTSP cameras inputs through API Calls (General Discussion)
by MartinC79 3/24/2026 2:51:41 AM(UTC)
Help with Dynamic Database Setup in Vmix (General Discussion)
by Tim P. 3/23/2026 7:12:35 AM(UTC)
Winner Third Help (GT)
by lehart 2/20/2026 3:26:29 AM(UTC)
help. mic wont work in output C (General Discussion)
by Streampunk 1/16/2026 2:21:54 AM(UTC)
Need help with NDI into vMix via Tailscale (NDI)
by knbPixels 1/14/2026 2:46:15 AM(UTC)
Help with Reference System (Systems)
Belarus tayproductions 12/16/2025 6:07:49 AM(UTC)
Professional Help (General Discussion)
by Rfritz1208 11/20/2025 3:24:23 AM(UTC)
Need Help About InstantReplay (Instant Replay)
by kadry 10/29/2025 6:32:53 AM(UTC)
Can I get help with Decklink 8k Pro and MacM4 Here? (General Discussion)
by pedalquickly 8/25/2025 8:02:49 AM(UTC)
Where i find vcall files any please help me (vMix Call)
by bistari 8/8/2025 11:12:28 PM(UTC)
Help with List, Playlists for a lot of Commercials & Graphics (General Discussion)
by Tim P. 7/21/2025 12:37:39 PM(UTC)
NDI Scan Converter – Frame Drop on M1 iMac, Will M4/M3 Macs Help? (NDI)
by dwsk527 6/30/2025 1:20:57 PM(UTC)
Laggy High Render Times. Upgrade help? (Hardware Compatibility)
by Lastmarine 5/13/2025 7:05:19 PM(UTC)
Need help with GT and pages (display multiple pages simultaneously?) (GT)
by TL68 4/3/2025 7:24:11 PM(UTC)
Help for a beginner who would like to write simple scripts (General Discussion)
by visioneimmagine 4/2/2025 1:27:04 AM(UTC)
Shortcut buttons on home page... very helpful (Feature Requests)
by obau 3/30/2025 10:35:23 AM(UTC)
help me my vmix keeps crashing (General Discussion)
by kamlesh4623 3/28/2025 6:34:22 PM(UTC)
I need help with a trigger please. (General Discussion)
by Kapelaan 3/14/2025 5:18:09 PM(UTC)
Help me please to setup a 6 camera vmix computer. (Systems)
by Alessandro B 3/13/2025 1:49:28 AM(UTC)
ASL interpreter window template help (General Discussion)
by ab800 2/12/2025 4:19:34 AM(UTC)
Help Needed with SMTAV IP PTZ Cameras Positioning Issue (Hardware Compatibility)
by jacan sevada 1/13/2025 12:14:50 PM(UTC)
Help with Capture Card (Hardware Compatibility)
by stamperdog 12/14/2024 7:29:57 AM(UTC)
Live Stream Help (General Discussion)
by Lighthouse_Gosport 11/25/2024 2:42:25 AM(UTC)
Help Need! SOS - NDI one desktop can not see the other (NDI)
by gujingc 11/13/2024 7:23:40 PM(UTC)
External Render Card - Help SOS (General Discussion)
by gujingc 10/14/2024 9:54:24 AM(UTC)
BCF2000 Setup Help in vMix (Hardware Compatibility)
by coultersound 7/28/2024 1:59:52 AM(UTC)
Need help with MultiCoder (General Discussion)
by Dave Galegor 7/18/2024 7:41:43 AM(UTC)
