GT
Need help with GT and pages (display multiple pages simultaneously?)
Joined: 12/8/2022(UTC) Posts: 169  Thanks: 53 times Was thanked: 3 time(s) in 3 post(s)
Hi! Building a scoreboard which contains extra graphic elements that I would like to show/hide indipendent of eachother. Trying to use pages for this but cannot get it to work as needed.
If i assign element 1 to page 1 I need to hide element 2 and 3 on page 1 If i assign element 2 to page 2 I need to hide element 1 and 3 on page 2 If i assign element 3 to page 3 I need to hide element 1 and 2 on page 3
I want to have a shortcut for each individual element that triggers it to show, and so that I can chose any combination to display of the three elements. Above works if I want to just display each element alone.
But how to solve so that I for example can press shortcut for element 1 (page1) and then element 2 (page2) and both stays displayed at the same time? If set up as above element 1 will hide when I press element 2 and vice versa. I hope the question is understandable. Any solution for this?
Joined: 12/27/2012(UTC) Posts: 5,541  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Originally Posted by: TL68  Hi! Building a scoreboard which contains extra graphic elements that I would like to show/hide indipendent of eachother. Trying to use pages for this but cannot get it to work as needed.
each page will show what is defined on it , can not stack pages and look through them just like real world pages Maybe look into hiding/showing each element (use fade for that with very short time)
Originally Posted by: doggy  Originally Posted by: TL68  Hi! Building a scoreboard which contains extra graphic elements that I would like to show/hide indipendent of eachother. Trying to use pages for this but cannot get it to work as needed.
each page will show what is defined on it , can not stack pages and look through them just like real world pages Maybe look into hiding/showing each element (use fade for that with very short time) Thanks for responding. Not sure I understand how to use the show/hide method though. Any manual or tutorial around for this?
GT
