help. mic wont work in output C
hello I use bus A and bus B for Zoom in/out and this time only I used bus C for record instead of master
somehow, one of my wireless mics is working in bus A and master as usual but not in sub C other mics and zoom-out are working in bus C properly
is it a hardware issue?
Im using a ryzen 7 laptop with 32GB ram and 3 hdmi outputs
thanks
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
Originally Posted by: Streampunk  hello I use bus A and bus B for Zoom in/out and this time only I used bus C for record instead of master
thanks Check the channel matrix of your mic input. If you enabled Bus C in the Audio Output settings AFTER you added the mic input and made changes to the channel matrix of the mic input BEFORE you enabled Bus C, Bus C is not active in the matrix.
 1 user thanked dmwkr for this useful post.
I enabled in the matrix and it worked right away, thanks!
