Streampunk
#1 Posted : Friday, January 16, 2026 2:21:54 AM(UTC)
Streampunk
Israel
hello
I use bus A and bus B for Zoom in/out
and this time only I used bus C for record instead of master
somehow, one of my wireless mics is working in bus A and master as usual but not in sub C
other mics and zoom-out are working in bus C properly
is it a hardware issue?
Im using a ryzen 7 laptop with 32GB ram and 3 hdmi outputs
thanks
dmwkr
#2 Posted : Friday, January 16, 2026 3:22:28 AM(UTC)
dmwkr
Originally Posted by: Streampunk Go to Quoted Post
hello
thanks
Check the channel matrix of your mic input. If you enabled Bus C in the Audio Output settings AFTER you added the mic input and made changes to the channel matrix of the mic input BEFORE you enabled Bus C, Bus C is not active in the matrix.
thanks 1 user thanked dmwkr for this useful post.
Streampunk on 1/16/2026(UTC)
Streampunk
#3 Posted : Friday, January 16, 2026 3:34:45 AM(UTC)
Streampunk
Israel
I enabled in the matrix and it worked right away, thanks!
