Bardos
#1 Posted : Sunday, July 5, 2015 2:41:33 PM(UTC)
Bardos
Groups: Guests
Just a simple question.....I usually stream on the same PC as vMix, but I find adding 2 or 3 cameras does put some heavy load on the PC, so I am looking at how to connect a second PC just for streaming......I know how to connect 2 PCs via the ethernet cable, but then I can not access the internet......
Charssay
#2 Posted : Sunday, July 5, 2015 5:18:55 PM(UTC)
Charssay
From your Vcard, fulscreen on the hdmi as second monitor.
On the second PC, capture this signal with a hdmi capture card.
Be careful with the audio delay.
Then process the live.
C.
Bardos
#3 Posted : Sunday, July 5, 2015 10:28:59 PM(UTC)
Bardos
Groups: Guests
I am using laptops with only USB ports, and Ethernet connections, no hdmi......I can get the two laptops connected and do screen capture into vMix, but can not connect to the internet after that....the Laptop can not access the internet with the setup
Charssay
#4 Posted : Monday, July 6, 2015 1:45:20 AM(UTC)
Charssay
Don't connect these both of them with a direct cable.
How do you connect the laptop on internet ? By Lan ?
I don't see the problem if both are connected on the same modem. It's the modem that give both Internet.
so, the setup cannot affected the connection on the second laptop
By the way, your Vmix laptop use the Video out (Vga, hdmi, dvi) as second screen and fullscreen there and connect this exit on a USB capture card in the second laptop, then live it on internet
ovinas
#5 Posted : Monday, July 6, 2015 1:47:33 AM(UTC)
ovinas
Speegs
#6 Posted : Monday, July 6, 2015 11:29:53 PM(UTC)
Speegs
You could also look at a hardware video encoder like the teradek vidiu (just a for instance) many others exist. You run a HDMI out to a box, it will encode the video. It would also require an Ethernet connection to your network switch unless of course you trust streaming via wifi (I generally don't).
Bardos
#7 Posted : Tuesday, July 7, 2015 9:22:36 AM(UTC)
Bardos
Groups: Guests
Please Read What I Say:......
I am using laptops with only USB ports, and Ethernet connections, NO HDMI......I can get the two laptops connected and do screen capture into vMix, but can not connect to the internet after that....the Laptop can not access the internet with the setup I am using
All I want to do is use one laptop for vMix, and another to stream.
ask
#8 Posted : Tuesday, July 7, 2015 5:02:11 PM(UTC)
ask
Bardos. You will need to take the video/audio across seperate to the Ethernet connection. If you have HDMI output on one of the laptops the Avermedia ExtremeCap U3 is a cost effective way of bringing in the signal via USB. If you only have USB, get a USB to HDMI adaptor to take the signal out then into a capture device. As for the connectivity to the internet issue, it almost sounds like both laptops are using the same IP address. You will need to do some basic network troubleshooting ensuring you have connectivity.
AndyB
#9 Posted : Sunday, July 19, 2015 3:45:35 PM(UTC)
AndyB
I would suggest that rather than investing on external equipment, which is costly to buy, needs careful setup and means more equipment to go wrong during a stream, why not upgrade the machine you're currently using?
Can you outline the spec of the PC, GPU and capture cards?
a
Bardos
#10 Posted : Wednesday, July 22, 2015 8:30:22 PM(UTC)
Bardos
Groups: Guests
Let me see if I can put this more plain:....I have a laptop with NO HDMI.....I have a PC with NO HDMI, just simple computers.....I have vMix on the laptop, and I go to an institution where they have OBS and wirecast for streaming....
What I want to do, is to use my laptop with vMix, to do a multi-input switching of a lecture with Q&A, and use their PC to stream, since it has all the streaming information, and is already setup to stream to wherever they are streaming.....
All I need to know, is how to connect the two computers together without losing the internet connection of the streaming PC as has been happening.....
sinc747
#11 Posted : Thursday, July 23, 2015 12:44:15 AM(UTC)
sinc747
Was thanked: 204 time(s) in 170 post(s)
Internet
As Ovinas suggested, use a network switch to split the internet connection so both PC/laptop can connect at the same time.
Video
Use the VGA-Out on the laptop to send video to a yet-to-be-purchased USB video capture device like an easycap USB frame grabber. You'll need a VGA-to-composite converter.
Audio
House audio can be sent to either/both systems to Line-In or Mic inputs.
Does this address your question?
Tom
richardgatarski
#12 Posted : Monday, July 27, 2015 10:13:22 AM(UTC)
richardgatarski
Bardos,
I agree with Tom's summary.
The idea of offloading your PC/laptop by streaming from another one does not work if you want to send your output over Ethernet. Because that means you need to "stream" to the other PC.
Bardos
#13 Posted : Tuesday, July 28, 2015 8:28:38 AM(UTC)
Bardos
Groups: Guests
I have also noticed that the Recorder seems to be using more CPU power than before....Yesterday, during a recording, I realised that my CPU was running as high as 75% in SD, one camera......I am used to 30 - 50% ....I was very surprise when I saw such a high CPU usage, as I always tell my friends how low the power cumsumption is.......I was recording in Mp4, as Mpeg2 is not possible with win8....
Similar Topics
Feature Request: Support FFmpeg NMR AAC Audio Encoder for streaming & recording (Feature Requests)
by zglloo479 10/14/2026 2:03:18 PM(UTC)
New vMix build 5 NDI 2 SDI streaming (Systems)
by alefello 8/18/2026 12:10:10 AM(UTC)
HEVC Encoding & 2K/1440p Twitch Streaming – A Real OBS Killer Feature (Feature Requests)
by freshpixel 5/14/2026 7:31:43 AM(UTC)
Streaming Problem On-Display Alert Option (Feature Requests)
by rjmurdock 4/24/2026 3:05:00 AM(UTC)
vMix streaming error I cannot solve (General Discussion)
by CaroliTNN 1/20/2026 5:34:48 AM(UTC)
Error in vMix during live streaming in HEVC format (General Discussion)
by marcos almeida 12/13/2025 10:20:31 PM(UTC)
BUFFERING ISSUE LIVE STREAMING (General Discussion)
by mcmcomp 12/10/2025 1:39:50 PM(UTC)
Streaming Title (General Discussion)
by sackboydad 12/8/2025 10:51:29 AM(UTC)
Temporary Solution AMD Streaming Encoder (3rd Party Software and Development)
by dux369 11/14/2025 10:03:10 AM(UTC)
Feature request: Add ability to specify YouTube channel for Live streaming (Feature Requests)
by AV_FUCV 11/12/2025 12:25:23 PM(UTC)
vMix竖屏直播功能 vMix Vertical Screen Live Streaming Function (Feature Requests)
by 导播之家 8/29/2025 2:47:37 PM(UTC)
Streaming to TikTok & Facebook with Comments (General Discussion)
by Simsyuk 7/18/2025 7:25:49 PM(UTC)
Twitch 2K Streaming HEVC and so... (General Discussion)
by freshpixel 6/18/2025 3:39:40 AM(UTC)
Unknown "Virtual" input when start streaming (General Discussion)
by thelotradio 6/13/2025 8:03:29 AM(UTC)
Question about streaming a movie on X-stream with subtitles (General Discussion)
by raid2001 6/13/2025 12:51:53 AM(UTC)
Input MPEG-TS Stream Losing Audio While LiveLAN is Streaming (General Discussion)
by tn0476 6/2/2025 7:17:07 AM(UTC)
Zoom Call - Just join a Zoom Call without record / Streaming (General Discussion)
by mcgeem1 5/31/2025 6:48:03 PM(UTC)
streaming to x and facebook groups (General Discussion)
by w5kub 5/20/2025 9:21:15 AM(UTC)
Nvidia 5080 Hardware Encoding not working in VMix Streaming (SOLVED) (Hardware Compatibility)
by pdvdw 3/25/2025 2:55:04 AM(UTC)
Streaming API Enhancements (Feature Requests)
by sackboydad 2/23/2025 2:04:30 AM(UTC)
Output 2 streaming with different framerate (General Discussion)
by davidkk 2/13/2025 12:43:27 AM(UTC)
Twitter streaming (General Discussion)
by w5kub 2/6/2025 6:39:06 AM(UTC)
Tiktok / Instagram streaming back end (General Discussion)
by tomtailford 2/6/2025 12:46:27 AM(UTC)
Twitter gone from streaming destinations (General Discussion)
by CaroliTNN 1/31/2025 12:31:00 PM(UTC)
SRT Stream to Wowza Video (formerly Wowza Streaming Cloud) (SRT)
by Follo 12/17/2024 2:00:47 AM(UTC)
24/7 streaming camera recommendations (General Discussion)
by FlamingoShow 11/16/2024 12:16:36 AM(UTC)
Motorsport Streaming via Remote Studio (Showcase)
by turn7media 10/30/2024 1:55:58 AM(UTC)
YouTube streaming issue (General Discussion)
by cdstream 10/17/2024 3:48:43 AM(UTC)
Streaming frame rate issue? (General Discussion)
by hiraiken 9/25/2024 6:44:26 PM(UTC)
Streaming cameras (General Discussion)
by Carol McFarland 8/28/2024 5:25:40 AM(UTC)
