mt_
#1 Posted : Friday, November 20, 2026 8:13:29 PM(UTC)
mt_
Poland
Product: vMix 30. Tested with Streaming (RTMP), Streaming with SRT, and External > SRT.
Area: Streaming Quality Settings > Audio Channels (MA / MAB / ABCD)
Summary
vMix can now stream more than stereo: MA (4 channels), MAB (6) and 8-channel modes such as ABCD. This is very useful for ingesting several buses at once, for example one commentary language per bus, and splitting them on the server.
The 6- and 8-channel streams are tagged as 5.1 and 7.1. In both layouts channel 4 is the LFE (subwoofer) channel. The AAC encoder used by Stream cuts the LFE channel to low frequencies only, below about 280 Hz. So in MAB the right side of Bus A is lost, and in ABCD (Bus A, B, C, D on channels 1-8) the right side of Bus B is lost. Speech on that side is practically gone.
External > SRT does not have this problem. With the same 8 channels it delivers channel 4 at full bandwidth. So vMix can already produce correct streams. Only the Stream output is affected.
What we measured
We fed each bus a different test tone (300-1130 Hz) and analysed the streams before any server processing.
  • Stream, RTMP, MA: 4 channels (layout 4.0), FLV. Channel 4: full bandwidth, OK.
  • Stream, RTMP, MAB: 6 channels (5.1), FLV. Channel 4: lowpassed (Bus A right tone missing).
  • Stream, RTMP, ABCD: 8 channels (7.1), FLV. Channel 4: lowpassed (Bus B right tone missing).
  • Stream, SRT, ABCD: 8 channels (7.1), MPEG-TS, FFmpeg native aac (Lavc60.3.100) + x264. Channel 4: lowpassed.
  • External > SRT, ABCD: 8 channels (7.1), MPEG-TS, a different AAC encoder. Channel 4: full bandwidth, OK.
The result is the same for vMix builds with older and newer FFmpeg.
The cause is inside FFmpeg, not in the receiving server. FFmpeg's native AAC encoder always limits the LFE element to the lowest 12 MDCT coefficients (libavcodec/aacenc.c, TYPE_LFE). No option changes this. In a local test, an 800 Hz tone on channel 4 of a 5.1 or 7.1 file came out 50 dB quieter than on channel 1, while 80 Hz passed unchanged.
Request
Please add a channel layout setting for multichannel streaming, or change the default so that every bus keeps full bandwidth. Any of these would solve it, in order of preference:
  1. Use the same AAC encoder as External > SRT for Stream outputs. It already writes 5.1/7.1 with a full-bandwidth channel 4. This works with existing servers. Wowza Streaming Engine decodes it correctly; we verified it.
  2. "Discrete (no LFE)" layout option: 6.0 / hexagonal for 6 channels and octagonal for 8 channels (FFmpeg -channel_layout). FFmpeg then encodes every channel at full bandwidth.
  3. Bus-to-channel placement option: let the user leave the LFE slot (channel 4) unused, for example MAB sent as 8 channels with an empty channel 4.
How to reproduce
  1. Set Master, Bus A and Bus B to different sources (different tones help).
  2. Streaming Quality Settings > Audio Channels: MAB. Stream to any RTMP or SRT receiver.
  3. Record the stream and listen to channel 4 alone, e.g.:
    Code:
    ffmpeg -i recording.flv -af "pan=mono|c0=c3" ch4.wav
    Only low frequencies remain.
  4. Do the same with External > SRT: channel 4 is full bandwidth.
We are happy to share recordings and analysis.
