Slaver
#1 Posted : Monday, March 23, 2015 7:34:49 PM(UTC)
Slaver
Was thanked: 8 time(s) in 8 post(s)
i used the search option a longer time, but didn´t find any answers to my question.
I need to know some more about the output opportunities in vMix.
I´am using 2 Displays for my livestreams. One is for the controls and ther other ist to
prove the stream. Both are connected via DVI.
No i want to send out the mixed signal(live-video whith overlays) to another bunch of
displays in the stadium. I can use SDI or HDMI doesn´t matter.
I want to buy a Blackmagic Decklink Monitor card for the new output. Anyone of you used
it before?
Does anyone has some experiences with such a configuration?
Where can i control the outputs in vMix?
Thanks a lot !
Cheers
DDOtoo
#2 Posted : Thursday, March 26, 2015 2:21:56 PM(UTC)
DDOtoo
I use Blackmagic Decklink quad for my output. In the settings under external I have ticked external renderer and selected, under the device option, my preferred output channel on the Decklink and it works fine except for severe lagging. It lags about 1 minute meaning I can't use that for live shows but more for replays and displaying information and the like. Having said that it could also be due to the distance between the control room and the external display. Mine is about 50m away.
tdurhamjr
#3 Posted : Thursday, March 26, 2015 4:31:12 PM(UTC)
tdurhamjr
Was thanked: 26 time(s) in 21 post(s)
Slaver,
What is the maximum number of displays that your streaming computer supports?
Tim
davesuemcbride
#4 Posted : Thursday, March 26, 2015 5:45:04 PM(UTC)
davesuemcbride
Roku gadgets are easy to deploy, have very good image quality, and very low cost, but I haven't had luck yet getting <20 seconds delay (Silverlight streaming may help but haven't had time yet to tinker). Teradek Cubes can cut the delay to ~1 second, but are expensive and tricky to set up. Both would work over TCP/IP, making distance less of an issue (you mention a stadium, so max cable lengths for video protocols could be an issue).
For streaming to drive the displays, you could create a local Wowza server, or create a Wowza server in the cloud - Azure makes it very easy to build one, and Wowza offers reasonable monthly terms for the software.
Slaver
#5 Posted : Saturday, March 28, 2015 7:36:45 PM(UTC)
Slaver
Thank you for reply.
@tdurhamjr
I have a asus geforce 750 ti graphic card with 2 DVI and 1 HDMI.
I always read on the Internet that Windows just support 2 Displays.
Any news i didnt know?
Slaver
tdurhamjr
#6 Posted : Saturday, March 28, 2015 8:18:06 PM(UTC)
tdurhamjr
@tdurhamjr
Slaver
You can run 3 displays on that graphics card. I also meant to ask
1. Are the stadium monitors showing SD or HD video?
2. How is the HD signal distributed to all the monitors in the stadium? I am wondering if the stadium is using Cat5 or SDI for the video signal?
3. How close is your streaming PC to the video input of the Stadium HD Monitor Input system?
If you are using an SDI splitter then using something like a Blackmagic Decklink Monitor would be good to output the SDI signal and run it straight to your stadium monitor system.
Tim
Slaver
#7 Posted : Wednesday, April 1, 2015 4:07:59 AM(UTC)
Slaver
@tdurhamjr
Thank your for response.
I try to bring 3 screens on the asus geforce 750 ti but i could not see them all on vmix. When i click on fullscreen, i just have one another Monitor. The 3rd shows up the blue dektop background.
Your questions:
1. The Stadium Monitors (12x) are showing up HD (Samsung UE60H6273).
2. We use those hdmi2ethernet connectors to extend the hdmi cable.
3. The computer is like 10m from the 12 port hdmi switch.
Cheers
tdurhamjr
#8 Posted : Wednesday, April 1, 2015 3:30:24 PM(UTC)
tdurhamjr
Slaver,
The first thing is to make sure all 3 monitors show up in windows properly. With 3 monitors hooked up, confirm you are utilizing all three monitors. Use the "Identify" function in your display settings to see the number assigned to each monitor. Note which number the HDMI monitor is.
Now in vMix.
1. Click on Settings in top right corner. You are now in the "Display" section
2. Under green DISPLAY 1 button in middle, click on the drop down menu to the right of word "Display".
3. Select the number that was displayed on the HDMI monitor in first step above. Then click on OK.
4. Add camera input or video input to vMix and make sure it is showing in OUTPUT window.
5. Click on FULLSCREEN dropdown menu located at top-center of vMix screen > Put mouse over DISPLAY1
6. Select what you want shown on DISPLAY1. You can map the Output, Preview, Multiview, or any active Input to the DISPLAY1. If you are wanting to show the vMix output on all the stadium monitors, then you will select OUTPUT.
7. After you have made your mapping select, click on the FULLSCREEN button itself. The button will turn green meaning the FULLSCREEN option is now on. IF you mapped "Output" in the previous step, then you now see the vMix Output on the HDMI Monitor.
8. Now that you know it is working, unplug the HDMI monitor and run and an HDMI cable from your video card to the HDMI switch input (which you said is about 12 meters from the PC). Here is a link to a 50' HDMI cable on Amazon for $14. http://amzn.com/B00RYRJYDG.
The higher versions of vMix will support 2 FULLSCREEN outputs where the basic versions will only support 1. But for what you are doing it sounds like you only need 1.
I hope this is clear and easy to understand.
Tim
Similar Topics
Mark the Inputs and Outputs that are assigned (Feature Requests)
by jet 11/23/2026 9:39:32 PM(UTC)
Decklink Duo 2 - 3 External Outputs (Hardware Compatibility)
by Puawai Productions 6/27/2026 10:18:14 AM(UTC)
Ability to set specific NDI port for Outputs (Feature Requests)
by jet 6/24/2026 7:39:23 PM(UTC)
expand the "Additional Outputs" menu (Feature Requests)
by Alain Lahaye 5/14/2026 1:23:21 AM(UTC)
Vmix inputs to be passed straight without busses or outputs (Feature Requests)
by Khutso Matlala 11/26/2025 4:37:45 PM(UTC)
Stream Error (Different outputs) (General Discussion)
by sergiomegom 10/12/2025 7:15:05 PM(UTC)
add outputs 2-4 to multiview (Feature Requests)
by gefiltafish 9/24/2025 6:25:09 PM(UTC)
Two Outputs for "Hybrid" Meetings (General Discussion)
by Metryq 9/22/2025 5:44:40 AM(UTC)
More NDI outputs (Feature Requests)
by michaelthomasbrennan 8/18/2025 11:32:10 PM(UTC)
Request to Increase the Number of Full-Screen Outputs in vMix (Feature Requests)
by medesan 3/18/2025 5:42:32 AM(UTC)
2 seperate outputs w/ 2 seperate overlay channels (General Discussion)
by klegault 2/1/2025 1:30:10 AM(UTC)
Allow Outputs in Multiview (and Multiview2) (Feature Requests)
by spinfold 1/29/2025 5:03:41 AM(UTC)
vMix 29 wishes: More outputs, even more multiview things (Feature Requests)
by Vuurmannetje 1/28/2025 9:17:07 PM(UTC)
Add ability to time offset audio in Stream, just like you do for Outputs. (Feature Requests)
by Highway20Productions 1/16/2025 3:56:17 AM(UTC)
Outputs does not keep correct souce after Input Reorder/Delete (Feature Requests)
by Highway20Productions 12/18/2024 4:25:45 PM(UTC)
Outputs information added to API XML-SRT information and Outputs appear or not in the API (FIXED) (Beta Discussion)
by nikosman88 11/22/2024 9:50:35 AM(UTC)
Weird behavior for Outputs 2-4 (SOLVED) (Beta Discussion)
by WaltG12 11/8/2024 3:39:48 PM(UTC)
Clearing Audio Outputs (General Discussion)
by Korbinian.Werner 7/24/2024 12:01:52 AM(UTC)
Renaming NDI Outputs (Feature Requests)
by Monkey666 7/23/2024 11:21:50 AM(UTC)
Zoom inputs as NDI outputs (Feature Requests)
by Takabrycheri 5/10/2024 6:49:13 PM(UTC)
How To Display Outputs in Multiviewer (General Discussion)
by mattford1 5/4/2024 8:18:52 PM(UTC)
Vertical and Horizontal outputs at same time (General Discussion)
by TracyPeterson 4/25/2024 6:11:53 AM(UTC)
NDI HX support on outputs (Feature Requests)
by bdaver 4/19/2024 10:05:20 PM(UTC)
Sending Mix inputs ("Submixers") as NDI outputs (Feature Requests)
by RuneK 4/15/2024 11:33:24 PM(UTC)
vMix Replay multiple outputs (Instant Replay)
by dasmedienatelier 4/4/2024 2:11:44 AM(UTC)
Honor Transitions on all OUTPUTs (Feature Requests)
by sagaofsage 4/3/2024 3:42:02 AM(UTC)
More than 2 full screen outputs (Feature Requests)
by RobSealey 2/23/2024 9:04:41 AM(UTC)
More Recording outputs! (Feature Requests)
by jet 2/20/2024 9:48:52 PM(UTC)
More virtual outputs (Feature Requests)
by fgolman 2/12/2024 9:18:09 AM(UTC)
Dedicated menu/UI change for SRT outputs (Feature Requests)
by Hypohamish 12/9/2023 10:02:28 PM(UTC)
