Feature Requests
Add ability to time offset audio in Stream, just like you do for Outputs.
Joined: 11/10/2024(UTC) Posts: 14  Location: Corvallis, OR Was thanked: 1 time(s) in 1 post(s)
Because we are using an ASIO patch bay and various other ASIO devices integrated with our vMix production, and because vMix is forcing such a large ASIO buffer, there is a significant audio delay with our productions (60ms). The output recordings have that solved as they have a parameter to offset the audio, and we use an offset of -60 to get it back in sync and it works great.
But for live streams, there is no parameter to offset the audio. Is this an oversite?
Originally Posted by: Highway20Productions  Because we are using an ASIO patch bay and various other ASIO devices integrated with our vMix production, and because vMix is forcing such a large ASIO buffer, there is a significant audio delay with our productions (60ms). The output recordings have that solved as they have a parameter to offset the audio, and we use an offset of -60 to get it back in sync and it works great.
But for live streams, there is no parameter to offset the audio. Is this an oversite? Each individual audio input can have a delay set
Thanks, I will try this. It would still be nice if it would work at a program level, just like the Output Settings are able to. Seems equivalent as in Hard Disk Output = Stream Output. To only have that setting on the hard disk output, and not the stream output seems like an oversite.
Feature Requests
