Highway20Productions
#1 Posted : Thursday, January 16, 2025 3:56:17 AM(UTC)
Because we are using an ASIO patch bay and various other ASIO devices integrated with our vMix production, and because vMix is forcing such a large ASIO buffer, there is a significant audio delay with our productions (60ms). The output recordings have that solved as they have a parameter to offset the audio, and we use an offset of -60 to get it back in sync and it works great.
But for live streams, there is no parameter to offset the audio. Is this an oversite?
#2 Posted : Thursday, January 16, 2025 4:44:12 AM(UTC)
Each individual audio input can have a delay set
#3 Posted : Thursday, January 16, 2025 4:50:14 AM(UTC)
Thanks, I will try this. It would still be nice if it would work at a program level, just like the Output Settings are able to. Seems equivalent as in Hard Disk Output = Stream Output. To only have that setting on the hard disk output, and not the stream output seems like an oversite.
