Monkey666
#1 Posted : Tuesday, July 23, 2024 11:21:50 AM(UTC)
Monkey666
I'm setting up a studio using vMIX as an NDI aggrogator (taking different SDI, HTML, camera and PTZ feeds in and rerouting it out via NDI to a larger confidence monitoring network). Using so many inputs means that I need communicate to everyone using the NDI network what the output names for vMIX are, which as you can imagine is a real pain. I think that adding a feature where you can rename vMIX's NDI outputs from something other than"vmix - output 1" etc or the camera name, in my case it's "decklink K pro (1) 1". That would help out so much as at the moment I'm having to create a cheat sheet for the random NDI signal names for unformillar users where having the sources labelled with that's inside the feed would make everything a lot easier.
richardgatarski
#2 Posted : Tuesday, July 23, 2024 6:23:26 PM(UTC)
richardgatarski
I asked for that many years ago https://forums.vmix.com/posts/t6110-Use-operator-defined-Input-names-for-NDI-Outputs. Have not been implemented.
Luckily, you can nowadays instead use https://ndi.video/tools/ndi-router-mac/ (works with windows too) or https://www.ndistuff.uk/...ndi-router-remote-panel/ to rename NDI sources.
Monkey666
#3 Posted : Tuesday, July 23, 2024 7:30:29 PM(UTC)
Monkey666
Originally Posted by: richardgatarski Go to Quoted Post
I asked for that many years ago https://forums.vmix.com/...t-names-for-NDI-Outputs. Have not been implemented.
Thanks for the inside word on the ZEN Router Richard. I'll check it out. I was trying to use the native NDI router but as it was still populating with the og vMIX outputs and camera names it just made it messier so I kind of steared away.
richardgatarski
#4 Posted : Tuesday, July 23, 2024 8:23:53 PM(UTC)
richardgatarski
Have you checked if https://ndi.video/tools/ndi-access-manager-mac/ can be used to clean up the clutter?
Monkey666
#5 Posted : Wednesday, July 24, 2024 11:47:15 AM(UTC)
Monkey666
I'm only just starting to get my head around that part of it. If you have any advice it would be greatly appricated!
