richardgatarski
#1 Posted : Tuesday, April 19, 2016 5:41:14 AM(UTC)
richardgatarski
When adding an NDI Input, the name of the sources from vMix running on another PC does not acknowledge if the Input's name has been changed.
mjgraves
#2 Posted : Tuesday, April 19, 2016 1:51:05 PM(UTC)
mjgraves
+1
tnorrell
#3 Posted : Thursday, April 21, 2016 12:36:37 PM(UTC)
tnorrell
Was thanked: 13 time(s) in 10 post(s)
I haven't tested this yet, so I want to clarify what you are saying.
You're suggesting that if you rename the source on the host/source machine, that the re-name should be honored at the client/reciever host? Or are you suggesting that the rename on the client be honored on the host?
I wouldn't be comfortable with one of my on-site tech's renaming an interface and it changing the designation on my system. If automatic rename is going to be a feature, I would like to suggest that there be a checkbox to allow it or not.
I think in a perfect world there would be a 'global' option that would allow/deny this feature for all the inputs on this (local) machine, but then a 'per input' option that would all the global option to be overridden.
Just to overstate my perspective, i believe that enabling the automatic renaming of inputs based on updates from another system could be a problem. (think security)
richardgatarski
#4 Posted : Thursday, April 21, 2016 1:22:56 PM(UTC)
richardgatarski
Let's say I add a Camera Input, and vMix names it "HD Webcam" (from the device driver's info).
I then change the name in vMix to "Cam1", which is what is displayed in vMix (small) preview monitor,
If I turn on the NDI settings in vMix to Output "Cameras / Audio outputs" that camera is recognized as the NDI source "HD Webcam". But I want it to be recognized on other PCs as the name I decided to use. Or at least be able to optionally select if default or user defined names should be used when vMix outputs to NDI.
Hope that clarifies. And I see no security problems here...
EDIT: I am not asking that vMix should be able to rename NDI devices on other systems.
