I'm setting up a studio using vMIX as an NDI aggrogator (taking different SDI, HTML, camera and PTZ feeds in and rerouting it out via NDI to a larger confidence monitoring network). Using so many inputs means that I need communicate to everyone using the NDI network what the output names for vMIX are, which as you can imagine is a real pain. I think that adding a feature where you can rename vMIX's NDI outputs from something other than"vmix - output 1" etc or the camera name, in my case it's "decklink K pro (1) 1". That would help out so much as at the moment I'm having to create a cheat sheet for the random NDI signal names for unformillar users where having the sources labelled with that's inside the feed would make everything a lot easier.
Originally Posted by: richardgatarski  Thanks for the inside word on the ZEN Router Richard. I'll check it out. I was trying to use the native NDI router but as it was still populating with the og vMIX outputs and camera names it just made it messier so I kind of steared away.
Originally Posted by: richardgatarski  I'm only just starting to get my head around that part of it. If you have any advice it would be greatly appricated!
