Joined: 12/16/2014(UTC) Posts: 5 Location: Greenwich CT
I'm looking to rebuild one of my video rigs and looking for a new graphics card to instal in my rack mount computer. I'm looking at the nvidia gtx980. Does anyone know if this card will be compatible? Thx. Matt
Yes, any of the Nvidia or AMD cards from recent years is compatible. Just a note though, if you are getting the card just for Vmix a 980 GTX is quite a bit of overkill.
Thanks: 1 times Was thanked: 5 time(s) in 5 post(s)
fordry wrote:Yes, any of the Nvidia or AMD cards from recent years is compatible. Just a note though, if you are getting the card just for Vmix a 980 GTX is quite a bit of overkill. Wouldn't that depend on the number of inputs and their resolutions?
