Hardware Compatibility
How well will a RTX PRO 4000 Blackwell 24GB graphics card work?
Joined: 12/8/2022(UTC) Posts: 167  Thanks: 51 times Was thanked: 3 time(s) in 3 post(s)
Hi! In discussions with our companys computer provider they suggest a PC with a NVIDIA RTX PRO 4000 Blackwell 24 GB 4DP Graphics card for a Topaz/Obtanium level vMix setup. This instead of the GeForce RTX 5070 Ti 16G or NVIDIA Geforce RTX 4080 SUPER 16GB suggested in the vMix specs.
Except for being more expensive, how will the RTX PRO 4000 24GB work in a vMix setup?
Thanks in advance for any input regarding this!
Joined: 11/23/2020(UTC) Posts: 249  Location: Wichita Thanks: 14 times Was thanked: 32 time(s) in 28 post(s)
That card should be an improvement over the Gamer cards for video BUT may be overkill unless you're planning to run multiple 4K cameras and or video streams.
 1 user thanked Roy Sinclair for this useful post.
