Hardware Compatibility
configuration graphics cards external output
hi all, is there a way to configure two different external output with two different graph cards? i have a 2060 gtx, with 2 decklink duo 2 and 1 4x hdmi output bmd. i cant route my external output to the sdi output of the decklink. my first output for windows screen id on hdmi 1, the second display is on the second, which is working as external 1 on vmix. so all my 4 output hdmi works with my external, but not my sdi out from the decklink cards. is there a way to use multiples graphics cards for output what we want?
thanks
this should work first (if not alredy done) is to seperate the SDIs with the BMD Desktop Video Setup you also can setup the Labels of the SDI connectors there
in vMix Settings / External Output check External Renderer ON Device : select the correct SDI Port Port : SDI
then hit External and you should have the SDI Out on your Decklink (have it in two machines without issue)
