mixsystem
#1 Posted : Monday, September 19, 2016 5:27:55 PM(UTC)
mixsystem
there is a decoder that can receive the signal from Vmix ? I'll explain: now I get the flow with a PC on the network and would like a physical VLC decoder that is, I do not want to use a PC , you can do ?
thanks I await answers
vojam2001
#2 Posted : Thursday, September 22, 2016 3:34:29 AM(UTC)
vojam2001
RTMP server is needed for signal reception.
Mathijs
#3 Posted : Thursday, September 22, 2016 5:18:23 AM(UTC)
Mathijs
At recording setup, you can choose WMV streaming. That will make a wmv stream available on port 8080, which you can access with mediaplayer or vlc with url mms://ip-op-vmix-machine:8080
Similar Topics
Who will be the first to make a hardware based OMT decoder? (OMT - Open Media Transport)
by jet 10/27/2026 9:20:31 PM(UTC)
[SOLVED] vMix freezing when opening Decoders tab in Settings (Hardware Compatibility)
by ryxyz 7/30/2024 2:19:35 AM(UTC)
Decoder Missing (General Discussion)
by Soapm 7/18/2024 6:38:06 AM(UTC)
ATEM STREAMING BRIDGE as video decoder for vmix users (Feature Requests)
by mnmilos 10/30/2023 6:44:14 PM(UTC)
vMix 26 hangs when clicking on "Decoder" menu in the settings (General Discussion)
by Morki 6/3/2023 7:11:46 AM(UTC)
Crash/Hang when accessing 'Decoders' tab; fresh install on fresh Win11 box (General Discussion)
by beepchirpwhirr 11/4/2022 2:25:03 PM(UTC)
SRT caller Decoder Delay not working (SRT)
by gre2gor 7/12/2021 9:33:11 PM(UTC)
vMix might hang on exit if SRT Input uses hardware decoder and... (SRT)
by richardgatarski 7/8/2021 3:38:59 AM(UTC)
Birddog Flex decoder no audio (NDI)
by tarek 4/1/2021 12:17:43 AM(UTC)
vMix SRT to Makito X4 Decoder (SRT)
by topherharris 10/8/2020 5:32:03 AM(UTC)
Which SRT-HEVC-FHD Hardware decoder are good value for money ? (SRT)
by TV97 5/15/2020 10:04:18 AM(UTC)
Vmix stream to Teradek Decoder (General Discussion)
by bnaivar 2/12/2020 4:38:08 AM(UTC)
h264 CPU decoder-Encoder (General Discussion)
by macgiver76 6/28/2018 1:59:21 AM(UTC)
Settings>Decoders Access Causes System Hang (General Discussion)
by Sid Stafford 11/6/2017 7:48:54 PM(UTC)
Decoder being used by vMix (Feature Requests)
by lbgaus 4/27/2016 10:36:25 AM(UTC)
MPEG 2 Video Decoder, Pal 50p and mpeg2-ts (General Discussion)
by Guest 4/16/2013 6:29:48 AM(UTC)
