there is a decoder that can receive the signal from Vmix ? I'll explain: now I get the flow with a PC on the network and would like a physical VLC decoder that is, I do not want to use a PC , you can do ? thanks I await answers
RTMP server is needed for signal reception.
At recording setup, you can choose WMV streaming. That will make a wmv stream available on port 8080, which you can access with mediaplayer or vlc with url mms://ip-op-vmix-machine:8080
