melody
#1 Posted : Tuesday, April 16, 2013 6:29:48 AM(UTC)
Rank: Guest
Groups ready for retrieval: Guests
hi martin,
i have some thins to tell you about this weekend using vMix.
at first, on the decoders tab, i allways used "Auto" on MPEG 2 Video and sometimes on my firewire inputs some green and black blocks has been showed after undeterminated minutes. in some extremely cases, the hole input goes green for an unknown reason. yesterday when i switch on my computer and opened vMix my firewire inputs started to had that problems with green and black blocks. so then i decided to change the MPEG 2 Video on decoders tab to LAV Video Decoder excluding hardware acceleration. i can tell you that all those green and black blocks was gone definitely. here goes my LAV settings:
after change to LAV decoder, the streaming and the recording was sucessfull. all worked better than before.
well, another thing to say, today i tried to use the same settings for record at progressive 50 fps and when i click OK on Recording Setup settings vmix shows me an error... "Codec Not Supported..." sended error report.
is there any possibility to record at 50fps using mpeg2-ts?
regards,
melody
www.espiritosanto.cc
