8 Pages«<678
desmar
#141 Posted : Saturday, April 9, 2016 2:44:09 PM(UTC)
desmar
Canada
When adding Colour input
setting any of the 5 inputs to pictures etc.... in Multiview for Colour Input
It will not display the overlay inputs regardless if color is set to a colour, colour bars or transparent
when overlay 1 is selected.
desmar attached the following image(s):
lbgaus
#142 Posted : Saturday, April 9, 2016 6:39:28 PM(UTC)
lbgaus
Possible bug to report, I am testing a new system on the version 17 beta.
This doesn't appear to negatively impact vMix but sometimes I am running shortcuts from a script and on occasion (not predictably) I receive GUI vMix error messages. The log file prints this out:
17.0.0.70 - Unhandled - 4/8/2016 2:30:05 PM
System.NullReferenceException: Object reference not set to an instance of an object.
at la.c(Object a, EventArgs a)
at kz.a.Invoke(Object sender, EventArgs e)
at iz.zzb()
at iz.zzzzzh()
at iz.zb(jg a)
Any ideas? Thanks for your time and energy. :)
#143 Posted : Saturday, April 9, 2016 9:57:23 PM(UTC)
Was thanked: 4740 time(s) in 1626 post(s)
Sorry, I cant see capture 1 or 2, can you send them again?
#144 Posted : Saturday, April 9, 2016 9:57:43 PM(UTC)
Can you update it to the latest beta, version .75?
#145 Posted : Sunday, April 10, 2016 9:46:22 AM(UTC)
desmar,
So I have worked out what this is happening.
The maximum number of overlays allowed in Basic HD is 1.
As a side effect of this any multiview inputs will not show in overlays only the main input.
So upgrading to HD will solve your problem.
desmar on 4/10/2016(UTC)
#146 Posted : Sunday, April 10, 2016 10:29:41 AM(UTC)
vMix 17.0.0.76 is now available
Please use the download link at the start of this thread.
Changes and Fixes
* Fixed object reference bug on closing inputs
* Fixed error when loading XAML Title preset with an image that doesn't exist
* Fixed right click menu for title presets where a preset contained a lot of text
vMix Desktop Capture for Mac has also been updated with a number of bug fixes, it can be found on the NDI page
http://www.vmix.com/ndi/
corporatejames on 4/10/2016(UTC)
corporatejames
#147 Posted : Sunday, April 10, 2016 6:36:48 PM(UTC)
corporatejames
Thanks Martin, I knew you would fix it quickly. I will confirm today.
Updated: Tested and confirm it resolved the issue with a long title preset string from a CSV data file.
Martin "Your the man!" Next step on the WISH LIST! XAML title data from a XML url/file
ccolewilliam
#148 Posted : Sunday, April 10, 2016 8:54:49 PM(UTC)
ccolewilliam
I just downloaded the test version of VMix17. The Chroma Key is a massive improvement. That was my only complaint ever. True pro HD quality without the need of any Anti Aliasing! My only question is on the desktop capture. I use that on about 5 different computer sources. One of them is an old basic xp computer. I know VMix doesn't support that at all. But I was always able to download desktop capture independently for that computer. Is it possible to still use the old desktop capture with the new 17 or is there a way to download the new capture separately. Also, I have about 250 inputs. And it takes about 5 minutes to load in 16 it took maybe 1 minute to load everything up in 17. There are major improvements with this version for sure. Great work! -William
Edit: I just answered all of my questions with the desktop capture. I found the separate download link and it works. Again great update. Solved the only few issues I have ever had with Vmix over the last couple of years.
pstuart
#149 Posted : Sunday, April 10, 2016 10:21:51 PM(UTC)
pstuart
PTZ
* Support for "Web Enabled" Sony, Canon and PTZ Optics PTZ control
Is there any docs for enabling the Canon PTZ functions? I have several canon xa20's that have the built in web controls, but I can't seem to get the zoom option to work (or anything) in the PTZ section of the camera.
I assume this isn't working?
Not sure how useful it would be anyway, since you can only do web control with direct Wifi connection to the camera, it doesn't connect to the wifi network and then allow connection on full network...
phab
#150 Posted : Monday, April 11, 2016 3:27:26 AM(UTC)
phab
I have a problem in setting audio input>Flash/RTMP> YouTube video.
When I played the youtube video, audio level in audio mixer is not working...
Phab
vmix preview 17.0.0.76
#151 Posted : Monday, April 11, 2016 4:20:41 AM(UTC)
Phab
This is a YouTube limitation, you might have better luck using the Web Browser input instead.
phab
#152 Posted : Monday, April 11, 2016 5:20:33 AM(UTC)
phab
Great, how automatic youtube video play in full screen after "quick play transistion" ?
#153 Posted : Monday, April 11, 2016 8:22:50 AM(UTC)
vMix 17 (17.0.0.76) has now been posted to the web site as the release version!
http://forums.vmix.com/d....aspx?g=posts&t=6066
See the main release thread for all further discussion.
lbgaus on 4/11/2016(UTC)
Guest (10)
8 Pages«<678
