Joined: 8/21/2015(UTC) Posts: 324   Location: Cornwall, Ontario, Canada Thanks: 18 times Was thanked: 80 time(s) in 60 post(s)
When adding Colour input see Capture1.PNG setting any of the 5 inputs to pictures etc.... in Multiview for Colour Input seen Capture2.PNG It will not display the overlay inputs regardless if color is set to a colour, colour bars or transparent when overlay 1 is selected. see Capture3.PNG desmar attached the following image(s):  Capture1.PNG (18kb) downloaded 1 time(s). Capture2.PNG (253kb) downloaded 2 time(s). Capture3.PNG (476kb) downloaded 7 time(s).You cannot view/download attachments. Try to login or register.
Joined: 11/30/2013(UTC) Posts: 165 Location: Seoul, South Korea
Thanks: 39 times Was thanked: 19 time(s) in 14 post(s)
Possible bug to report, I am testing a new system on the version 17 beta.
This doesn't appear to negatively impact vMix but sometimes I am running shortcuts from a script and on occasion (not predictably) I receive GUI vMix error messages. The log file prints this out:
======================================== 17.0.0.70 - Unhandled - 4/8/2016 2:30:05 PM ======================================== System.NullReferenceException: Object reference not set to an instance of an object. at la.c(Object a, EventArgs a) at kz.a.Invoke(Object sender, EventArgs e) at iz.zzb() at iz.zzzzzh() at iz.zb(jg a)
Any ideas? Thanks for your time and energy. :)
Joined: 1/13/2010(UTC) Posts: 5,337  Location: Gold Coast, Australia Was thanked: 4740 time(s) in 1626 post(s)
desmar wrote:When adding Colour input
Sorry, I cant see capture 1 or 2, can you send them again?
lbgaus wrote:Possible bug to report, I am testing a new system on the version 17 beta.
Can you update it to the latest beta, version .75?
desmar,
So I have worked out what this is happening. The maximum number of overlays allowed in Basic HD is 1. As a side effect of this any multiview inputs will not show in overlays only the main input.
So upgrading to HD will solve your problem.
Martin vMix
vMix 17.0.0.76 is now availablePlease use the download link at the start of this thread. Changes and Fixes* Fixed object reference bug on closing inputs * Fixed error when loading XAML Title preset with an image that doesn't exist * Fixed right click menu for title presets where a preset contained a lot of text vMix Desktop Capture for Mac has also been updated with a number of bug fixes, it can be found on the NDI page http://www.vmix.com/ndi/
Thanks Martin, I knew you would fix it quickly. I will confirm today.
Updated: Tested and confirm it resolved the issue with a long title preset string from a CSV data file. Martin "Your the man!" Next step on the WISH LIST! XAML title data from a XML url/file
Joined: 10/5/2015(UTC) Posts: 47  Location: Norman, Oklahoma
I just downloaded the test version of VMix17. The Chroma Key is a massive improvement. That was my only complaint ever. True pro HD quality without the need of any Anti Aliasing! My only question is on the desktop capture. I use that on about 5 different computer sources. One of them is an old basic xp computer. I know VMix doesn't support that at all. But I was always able to download desktop capture independently for that computer. Is it possible to still use the old desktop capture with the new 17 or is there a way to download the new capture separately. Also, I have about 250 inputs. And it takes about 5 minutes to load in 16 it took maybe 1 minute to load everything up in 17. There are major improvements with this version for sure. Great work! -William
Edit: I just answered all of my questions with the desktop capture. I found the separate download link and it works. Again great update. Solved the only few issues I have ever had with Vmix over the last couple of years.
Thanks: 1 times Was thanked: 4 time(s) in 2 post(s)
Quote:PTZ * Support for "Web Enabled" Sony, Canon and PTZ Optics PTZ control Is there any docs for enabling the Canon PTZ functions? I have several canon xa20's that have the built in web controls, but I can't seem to get the zoom option to work (or anything) in the PTZ section of the camera. I assume this isn't working? Not sure how useful it would be anyway, since you can only do web control with direct Wifi connection to the camera, it doesn't connect to the wifi network and then allow connection on full network...
Hi, I have a problem in setting audio input>Flash/RTMP> YouTube video. When I played the youtube video, audio level in audio mixer is not working...
Thanks Phab
vmix preview 17.0.0.76
phab wrote:Hi, I have a problem in setting audio input>Flash/RTMP> YouTube video. When I played the youtube video, audio level in audio mixer is not working...
Thanks Phab
vmix preview 17.0.0.76 This is a YouTube limitation, you might have better luck using the Web Browser input instead.
Quote:This is a YouTube limitation, you might have better luck using the Web Browser input instead. Great, how automatic youtube video play in full screen after "quick play transistion" ?
