AndyW69
#1 Posted : Friday, February 6, 2015 10:31:29 AM(UTC)
AndyW69
I am using the trial version of vmix (14 and now 15) with an asus thunderbolt laptop, aja 4kio and a BM ultrastudio (small one). I am having issues with the output latency. I am rigged up for testing thru my HDMI TV (similar latency with Sony pro monitor). If I output thru either the aja or BM I am getting 6-8 frames of delay (even on clip playback) longer on an HDSDI camera input (Canon XF-305). If I use the laptop HDMI output I am seeing 2 frames of delay (approx). The laptop is fine for testing but I really need to use a dedicated hardware output as I hope to use the system for high end corporate/broadcast events. I used to have a Newtek Toaster which always had at least 6 frame delay and its too much for projectors, I regularly work in broadcast and see 1 frame from the higher end switchers. I understand this is a 'cheap' solution, but have seen others doing the kind of jobs i believe would need a very low latency. I have disabled de-interlace and cannot see what else to try to reduce the latency further.
Any thoughts?
Andy
Similar Topics
HP Z8 G5 dual socket Xeon Gold 6526Y + DeckLink Quad 2 — compatibility and DPC latency concerns (General Discussion)
by Juan_Jav_Gonz 6/3/2026 1:45:50 AM(UTC)
Sharing Ultra Low Latency Audio and/or Video Content? (General Discussion)
by JohnDoe415 9/11/2025 9:17:35 AM(UTC)
Low Latency Monitor (General Discussion)
by Leapin 2/8/2025 6:42:23 AM(UTC)
vMix live IMAG via SDI inputs on a Thunderbolt 4 laptop - lowest latency option? (General Discussion)
by Paul CVP 10/3/2024 1:36:25 PM(UTC)
SRT latency & bitrate calculator (Feature Requests)
by mandurphy 12/28/2023 9:46:33 PM(UTC)
Nvidia Rivermax and low latency (Feature Requests)
by hadphild 9/7/2023 7:15:53 PM(UTC)
High encoding latency - i7 2600K 16GB RTX3070 (Systems)
by m_elias 8/9/2023 4:05:48 AM(UTC)
HLS with integrated VLC-Player => huge latency (over 60 seconds) (General Discussion)
by floh 7/20/2023 6:10:48 PM(UTC)
BlackMagic Design Micro Converter latency (General Discussion)
by JW 7/27/2022 5:47:43 AM(UTC)
Error when changing SRT Latency (SRT)
by fcl 6/18/2022 6:07:48 AM(UTC)
vMix Call Latency (vMix Call)
by Steven Forster 5/13/2022 6:05:02 AM(UTC)
SDI Input Latency in 2022 (Hardware Compatibility)
by paco3346 1/30/2022 1:18:17 AM(UTC)
Latency with and without NDI (NDI)
by muzicman82 10/16/2021 12:14:24 AM(UTC)
APC Latency (General Discussion)
by Red Emerald 6/18/2021 6:12:23 AM(UTC)
Managing Latency for multi-way chat (SRT)
by MattGrover 5/11/2021 12:57:05 AM(UTC)
higher audio latency vMix to vMix than vmix to Chrome (vMix Call)
by benwah 3/18/2021 8:35:50 AM(UTC)
Streaming setting -tune zerolatency (General Discussion)
by RoboST 3/10/2021 9:26:39 AM(UTC)
Latency match (SRT)
by mrpap 2/15/2021 9:13:05 PM(UTC)
vMix Social 'send to screen' latency (General Discussion)
by Podcast Bob 12/24/2020 8:06:42 PM(UTC)
Latency when using Wowza Cloud (General Discussion)
by TotalWebcasting 12/11/2020 5:39:01 AM(UTC)
Adjusting SRT Latency while live (SRT)
by TracyPeterson 10/11/2020 4:30:36 AM(UTC)
How to approach audio latency? (General Discussion)
by davenv 9/14/2020 8:58:07 PM(UTC)
Is this the best setup for low latency and good quality? (General Discussion)
by JW 9/5/2020 8:40:20 PM(UTC)
Low latency Output / CDNs (General Discussion)
by Nter 9/3/2020 2:11:40 AM(UTC)
Display Method and Low Latency v Smooth v Legacy (General Discussion)
by grantcoll 7/20/2020 8:54:09 AM(UTC)
NDI Latency and Adjustments (NDI)
by boris9831 7/4/2020 11:08:52 AM(UTC)
Dropped Frames and Latency (General Discussion)
by davenv 6/29/2020 1:43:02 AM(UTC)
Vmix call excessive video latency (vMix Call)
by andrewdavis 6/26/2020 5:32:22 AM(UTC)
Input latency problem with ASIO sound card buffer size (General Discussion)
Belarus ayo 6/21/2020 3:10:19 AM(UTC)
vMixcall Latency Problem (vMix Call)
by mnortham 6/7/2020 12:39:15 AM(UTC)
