Streaming setting -tune zerolatency
Thanks: 18 times Was thanked: 2 time(s) in 2 post(s)
We need to set this for fast encoding and low-latency streaming setting required by our host/cdn. Currently using vMix with the OBS application and would like to eliminate the OBS application if possible.
-tune zerolatency
Is there a way to do this with vMix (even recently released 24x version) streaming settings with Application: ffmpeg ?
Currently using vMix 21.0.0.61
More info for FFmpeg's -tune film – intended for high-bitrate/high-quality movie content. Lower deblocking is used here. animation – intended for cartoons, etc., where deblocking is boosted to compensate for larger, flat areas. More reference frames are used. grain – this should be used for material that is already grainy. Here, the grain won't be filtered out as much. stillimage – like the name says, it optimizes for still image encoding by lowering the deblocking filter. psnr and ssim – these are debugging modes[**debug] to optimize for good PSNR and SSIM values only. Better metrics don't necessarily mean better quality though. fastdecode – disables CABAC and the in-loop deblocking filter to allow for faster decoding on devices with lower computational power. zerolatency – optimization for fast encoding and low latency streaming
You can see the detailed options applied with each tune with x264 --fullhelp:
--tune <string> Tune the settings for a particular type of source or situation Overridden by user settings. Multiple tunings are separated by commas. Only one psy tuning can be used at a time.
- film (psy tuning): --deblock -1:-1 --psy-rd <unset>:0.15 - animation (psy tuning): --bframes {+2} --deblock 1:1 --psy-rd 0.4:<unset> --aq-strength 0.6 --ref {Double if >1 else 1} - grain (psy tuning): --aq-strength 0.5 --no-dct-decimate --deadzone-inter 6 --deadzone-intra 6 --deblock -2:-2 --ipratio 1.1 --pbratio 1.1 --psy-rd <unset>:0.25 --qcomp 0.8 - stillimage (psy tuning): --aq-strength 1.2 --deblock -3:-3 --psy-rd 2.0:0.7
- psnr** (psy tuning): --aq-mode 0 --no-psy - ssim** (psy tuning): --aq-mode 2 --no-psy
- fastdecode: --no-cabac --no-deblock --no-weightb --weightp 0 - zerolatency: --bframes 0 --force-cfr --no-mbtree --sync-lookahead 0 --sliced-threads --rc-lookahead 0
