cmacrae
#1 Posted : Tuesday, January 10, 2012 7:26:29 AM(UTC)
cmacrae
Hi there,
I am wanting to buy an intensity pro but I would like to know if you can capture and output to the intensity at the same time?
Cal
#2 Posted : Tuesday, January 10, 2012 7:44:33 AM(UTC)
Was thanked: 4734 time(s) in 1624 post(s)
Intensity Pro cards by design can either input or output but not both simultaneously.
Similar Topics
Blackmagic Decklink capture going offline (Hardware Compatibility)
by gseguin 8/18/2026 6:04:25 AM(UTC)
Decklink Quad2 port enumertion changing after PC restart (Hardware Compatibility)
by marieg 7/10/2026 1:56:26 AM(UTC)
Decklink Duo 2 - 3 External Outputs (Hardware Compatibility)
by Puawai Productions 6/27/2026 10:18:14 AM(UTC)
HP Z8 G5 dual socket Xeon Gold 6526Y + DeckLink Quad 2 — compatibility and DPC latency concerns (General Discussion)
by Juan_Jav_Gonz 6/3/2026 1:45:50 AM(UTC)
Green line at top and bottom when using DeckLink Duo 2 Fill/Key output in vMix (1080i59.94) (Hardware Compatibility)
by ken5o 2/14/2026 8:26:42 PM(UTC)
Any experienced with vMix and BMD DeckLink Quad 2 (Systems)
by TL68 12/19/2025 8:16:50 PM(UTC)
RTX 5080 & DeckLink 8K Pro G2 (chatgpt research) (Systems)
by clipads 11/2/2025 5:31:46 AM(UTC)
PCIE Capacity with Decklink Quad 2 (Systems)
by uofm36 9/4/2025 1:47:11 AM(UTC)
Renderer dropped (BMD Decklink) (Hardware Compatibility)
by tomtailford 8/29/2025 10:10:43 PM(UTC)
Can I get help with Decklink 8k Pro and MacM4 Here? (General Discussion)
by pedalquickly 8/25/2025 8:02:49 AM(UTC)
vMix output works but input doesnt on Decklink Quad 2 card (General Discussion)
by Bright7 8/12/2025 12:54:34 AM(UTC)
DeckLink Duo Not Showing as Input in vMix After Fresh Windows Install (Hardware Compatibility)
Belarus jbragancapt 7/29/2025 6:34:23 PM(UTC)
DeckLink 8K Pro G2 key & fill support (Hardware Compatibility)
by 3xscreen 7/3/2025 5:36:27 PM(UTC)
Blackmagic Decklink Quad HDMI returns Unsupported Video Format (Hardware Compatibility)
by wassers 5/23/2025 6:14:11 PM(UTC)
BMD DeckLink IP 100G (Hardware Compatibility)
by mavik 4/23/2025 3:52:24 AM(UTC)
Issue Decklink Duo 2 and desktop video 14.3 (only legacy wdm input vmix) (Hardware Compatibility)
by julien 11/27/2024 12:14:34 AM(UTC)
BM DeckLink 8K Pro G2 (Hardware Compatibility)
by s0wndman 10/22/2024 7:48:35 AM(UTC)
Problem with image capture via Decklink Quad 2 (Hardware Compatibility)
by svetotehnik 9/12/2024 1:06:12 AM(UTC)
Sending Key/Fill and Video from Decklink Duo 2. Is it possible? (Hardware Compatibility)
by fva 8/29/2024 2:09:37 AM(UTC)
Decklink Quad 2 in a Thunderbolt Enclosure (Hardware Compatibility)
by R0ll0verRandy 6/3/2024 2:22:41 AM(UTC)
Decklink Duo 2 Input Problem (Hardware Compatibility)
by dny18 5/12/2024 7:33:14 PM(UTC)
Decklink IP (Hardware Compatibility)
by samsp 2/27/2024 2:21:27 AM(UTC)
Problem with 2 Decklink Duo 2 cards (Hardware Compatibility)
by filmmaker75 2/5/2024 9:04:11 PM(UTC)
VMIX/BM Decklink Audio issues (General Discussion)
by emartinkgw 2/2/2024 4:01:25 AM(UTC)
PTZ Video Camera problem with DeckLink Quad 2 from BlackMagic (General Discussion)
by vinch3ster 12/14/2023 6:04:31 PM(UTC)
Confusing Error Message using BMD DecklinkCards (General Discussion)
by Jaa_Han 12/11/2023 8:50:32 PM(UTC)
Blackmagic Decklink Quad HDMI Recorder give massive delay after adding more than 2 source (Hardware Compatibility)
by khmerbrave 11/20/2023 9:20:21 PM(UTC)
vMix External Output to Decklink Duo problems (General Discussion)
by Bamboo 11/6/2023 2:48:25 AM(UTC)
Decklink Quad 2 + Sonnet Echo SE-IIIe compatibility issues (Hardware Compatibility)
by mburel1980 10/21/2023 5:52:27 AM(UTC)
Error when I external camera with card blackmagic decklink quad 2 (General Discussion)
by nhan7457 8/10/2023 2:16:24 AM(UTC)
