cmacrae
#1 Posted : Tuesday, January 10, 2012 7:26:29 AM(UTC)
cmacrae
Hi there,
I am wanting to buy an intensity pro but I would like to know if you can capture and output to the intensity at the same time?
Cal
#2 Posted : Tuesday, January 10, 2012 7:44:33 AM(UTC)
Was thanked: 4788 time(s) in 1643 post(s)
Intensity Pro cards by design can either input or output but not both simultaneously.
Similar Topics
Record incoming SDI timecode (RP188) from DeckLink inputs in MultiCorder and Record (Feature Requests)
by Andrea Angeli 10/23/2026 7:49:20 AM(UTC)
Blackmagic Decklink capture going offline (Hardware Compatibility)
by gseguin 8/18/2026 6:04:25 AM(UTC)
Decklink Quad2 port enumertion changing after PC restart (Hardware Compatibility)
by marieg 7/10/2026 1:56:26 AM(UTC)
Decklink Duo 2 - 3 External Outputs (Hardware Compatibility)
by Puawai Productions 6/27/2026 10:18:14 AM(UTC)
HP Z8 G5 dual socket Xeon Gold 6526Y + DeckLink Quad 2 — compatibility and DPC latency concerns (General Discussion)
by Juan_Jav_Gonz 6/3/2026 1:45:50 AM(UTC)
Green line at top and bottom when using DeckLink Duo 2 Fill/Key output in vMix (1080i59.94) (Hardware Compatibility)
by ken5o 2/14/2026 8:26:42 PM(UTC)
Any experienced with vMix and BMD DeckLink Quad 2 (Systems)
by TL68 12/19/2025 8:16:50 PM(UTC)
RTX 5080 & DeckLink 8K Pro G2 (chatgpt research) (Systems)
by clipads 11/2/2025 5:31:46 AM(UTC)
PCIE Capacity with Decklink Quad 2 (Systems)
by uofm36 9/4/2025 1:47:11 AM(UTC)
Renderer dropped (BMD Decklink) (Hardware Compatibility)
by tomtailford 8/29/2025 10:10:43 PM(UTC)
Can I get help with Decklink 8k Pro and MacM4 Here? (General Discussion)
by pedalquickly 8/25/2025 8:02:49 AM(UTC)
vMix output works but input doesnt on Decklink Quad 2 card (General Discussion)
by Bright7 8/12/2025 12:54:34 AM(UTC)
DeckLink Duo Not Showing as Input in vMix After Fresh Windows Install (Hardware Compatibility)
by jbragancapt 7/29/2025 6:34:23 PM(UTC)
DeckLink 8K Pro G2 key & fill support (Hardware Compatibility)
by 3xscreen 7/3/2025 5:36:27 PM(UTC)
Blackmagic Decklink Quad HDMI returns Unsupported Video Format (Hardware Compatibility)
by wassers 5/23/2025 6:14:11 PM(UTC)
BMD DeckLink IP 100G (Hardware Compatibility)
by mavik 4/23/2025 3:52:24 AM(UTC)
Issue Decklink Duo 2 and desktop video 14.3 (only legacy wdm input vmix) (Hardware Compatibility)
by julien 11/27/2024 12:14:34 AM(UTC)
BM DeckLink 8K Pro G2 (Hardware Compatibility)
by s0wndman 10/22/2024 7:48:35 AM(UTC)
Problem with image capture via Decklink Quad 2 (Hardware Compatibility)
by svetotehnik 9/12/2024 1:06:12 AM(UTC)
Sending Key/Fill and Video from Decklink Duo 2. Is it possible? (Hardware Compatibility)
by fva 8/29/2024 2:09:37 AM(UTC)
Decklink Quad 2 in a Thunderbolt Enclosure (Hardware Compatibility)
by R0ll0verRandy 6/3/2024 2:22:41 AM(UTC)
Decklink Duo 2 Input Problem (Hardware Compatibility)
by dny18 5/12/2024 7:33:14 PM(UTC)
Decklink IP (Hardware Compatibility)
by samsp 2/27/2024 2:21:27 AM(UTC)
Problem with 2 Decklink Duo 2 cards (Hardware Compatibility)
by filmmaker75 2/5/2024 9:04:11 PM(UTC)
VMIX/BM Decklink Audio issues (General Discussion)
by emartinkgw 2/2/2024 4:01:25 AM(UTC)
PTZ Video Camera problem with DeckLink Quad 2 from BlackMagic (General Discussion)
by vinch3ster 12/14/2023 6:04:31 PM(UTC)
Confusing Error Message using BMD DecklinkCards (General Discussion)
by Jaa_Han 12/11/2023 8:50:32 PM(UTC)
Blackmagic Decklink Quad HDMI Recorder give massive delay after adding more than 2 source (Hardware Compatibility)
by khmerbrave 11/20/2023 9:20:21 PM(UTC)
vMix External Output to Decklink Duo problems (General Discussion)
by Bamboo 11/6/2023 2:48:25 AM(UTC)
Decklink Quad 2 + Sonnet Echo SE-IIIe compatibility issues (Hardware Compatibility)
by mburel1980 10/21/2023 5:52:27 AM(UTC)
