Kamzar
#1 Posted : Wednesday, May 7, 2014 5:03:25 AM(UTC)
Kamzar
Hi guys im from South Africa, i'm planning to buy Avermedia Digital Video Surveillance System NV3000. whats your opinion about the card?
Here's my setup: x2 Sony PD170 SD Cam, i5 PC win7, philips HDD Rec, and Sanyo 3500 ansi lum Proj.
Charssay
#2 Posted : Wednesday, May 7, 2014 10:25:04 AM(UTC)
Charssay
Hello
If you intend to use the 4 port of this card, forget it. Only One V-in will be available under Vmix
Rgds
C.
Similar Topics
Out for Program w/o capture card (General Discussion)
by pllcoolj 8/24/2026 6:49:45 AM(UTC)
most stable SDI capture card (Hardware Compatibility)
by konstantinos 1/8/2026 9:47:51 AM(UTC)
vMix Capture Card Low Frame Rate (General Discussion)
by JohnDoe415 7/4/2025 10:02:42 AM(UTC)
External HDMI capture card for a PC? (Hardware Compatibility)
by clipads 12/16/2024 3:00:21 AM(UTC)
Help with Capture Card (Hardware Compatibility)
by stamperdog 12/14/2024 7:29:57 AM(UTC)
Troubleshooting CPU overload in Vmix with 3 cameras and Blackmagic capture card (General Discussion)
by GameWithSasha 3/27/2024 8:03:39 AM(UTC)
GPU and/or Capture card? (General Discussion)
by TechDad 2/12/2024 5:46:42 AM(UTC)
Capture Card Not Showing UP (need help ASAP) (General Discussion)
by lucaseccc 9/6/2023 1:14:35 PM(UTC)
Yuan Capture Cards / Input-Output (Hardware Compatibility)
by Slaver 5/9/2023 11:27:31 PM(UTC)
Datapath VisionSDI2 Capture Card Compatibility (Hardware Compatibility)
by stevematthews 2/22/2023 10:02:42 PM(UTC)
Max # PCI lanes - Asus Z790-P with dual capture card (Systems)
by TuurT 1/23/2023 7:10:42 AM(UTC)
pcie slot for capture card (Hardware Compatibility)
by ADAMKAV 1/8/2023 10:53:50 PM(UTC)
M2 Capture Cards and Heat (Hardware Compatibility)
by TRMaCoy 6/24/2022 3:06:27 AM(UTC)
Black Magic Design Duo 2 capture card NOT detected in PC (Hardware Compatibility)
by gez737 6/14/2022 3:47:05 PM(UTC)
BMD decklink quad HDMI recorder capture card (Hardware Compatibility)
by Cindy Drozda 4/26/2022 9:17:18 AM(UTC)
Delta cast capture card (General Discussion)
by Joeboe 11/16/2021 4:15:24 AM(UTC)
New Capture Card (General Discussion)
by Joeboe 10/29/2021 8:26:40 AM(UTC)
New Capture Cards (General Discussion)
by Joeboe 10/16/2021 11:03:33 AM(UTC)
NDI & Capture Card Output Combo Will you Review my Flowchart? (General Discussion)
by MPTESE 9/17/2021 2:01:39 PM(UTC)
AJA Capture Card (Hardware Compatibility)
by Joeboe 9/9/2021 8:23:47 PM(UTC)
USB Capture card for "External output" (Hardware Compatibility)
by yann35 6/4/2021 2:59:48 PM(UTC)
Not showing feed from HD capture card (Hardware Compatibility)
by RachaelAH 4/1/2021 4:16:44 AM(UTC)
120 or 240fps camera and capture card for vmix24 (Hardware Compatibility)
by omo 3/17/2021 5:57:39 PM(UTC)
NDI vs Capture card: which is more cpu heavy? (General Discussion)
by andreypetr 12/7/2020 11:04:00 PM(UTC)
2x BMD 8 Ch Capture cards on vmix issue (General Discussion)
by BigApple 10/11/2020 9:57:32 AM(UTC)
Using HDMI to USB capture card "dongle" (Hardware Compatibility)
by Gene Naber 10/9/2020 2:35:48 AM(UTC)
Help Choosing Capture Card! (General Discussion)
by Nina 9/12/2020 10:00:50 AM(UTC)
Need Help Choosing Capture Card (General Discussion)
by glbtrekker 9/5/2020 12:00:25 AM(UTC)
Multiple External Output Via Capture Card (Feature Requests)
by Person1 8/9/2020 8:45:31 PM(UTC)
Cheap USB capture card (2.0) (Hardware Compatibility)
by erikhogeboom 7/28/2020 9:08:21 PM(UTC)
