baz06
#1 Posted : Friday, December 20, 2013 2:48:00 PM(UTC)
baz06
Hi
I'm using vMix with 2 IP cameras (DLink dsc 3716).
With VLC, there is no problem to access the cameras with the string: rtsp://xx.xx.xx.xx/live.sdp
Unfortunately, the mix does not accept this link.
What did I do wrong?
Similar Topics
IP Camera No picture (General Discussion)
by Simsyuk 4/1/2023 5:27:01 AM(UTC)
H.265 IP Camera Support (General Discussion)
by muzicman82 7/13/2022 4:04:50 AM(UTC)
RTSP IP Camera Input Image loss (General Discussion)
by robocox 2/20/2021 1:22:46 AM(UTC)
VMIX CALL - Flip Camera Guest interface (Feature Requests)
by MBVideoNJ 7/1/2020 12:16:07 PM(UTC)
IP Camera gives video via RTSP and audio via VLC? (Hardware Compatibility)
by StryderTV 5/15/2020 8:19:30 PM(UTC)
vMix locks up when I attempt to add IP Camera on Website or NDI (NDI)
by Pappabear 2/6/2020 2:40:28 AM(UTC)
Ip Camera Set Up (NDI)
by TWOTC 6/25/2019 11:03:15 AM(UTC)
IP camera - RTSP Stream setup don't work ? (General Discussion)
by Rob75 1/28/2019 10:33:22 PM(UTC)
IP camera config (General Discussion)
by display 4/28/2017 11:22:07 AM(UTC)
IP Camera connection - Freezing stream (General Discussion)
by randys 4/8/2017 3:05:24 PM(UTC)
IP camera issue (General Discussion)
by cruiseweekTV 12/1/2016 10:37:45 AM(UTC)
IP Camera Limit? (General Discussion)
by BluestemVideo 11/25/2016 10:33:22 PM(UTC)
3 years trying to get an IP Camera for vMix with audio that stays in sync (General Discussion)
by antardwip 11/24/2016 5:55:58 AM(UTC)
IP Camera recording (General Discussion)
by EliYahu 8/26/2016 10:16:36 AM(UTC)
Need IP Camera solution POE/HD (General Discussion)
by kjones9999 3/14/2016 6:59:14 PM(UTC)
Need A Recommendation for a Wireless IP Camera for vMix RTSP Input (Hardware Compatibility)
by rjmurdock 8/26/2015 1:12:18 PM(UTC)
Using ip camera via your program (Hardware Compatibility)
by Ulyev 8/24/2015 2:08:40 PM(UTC)
Using Axis IP Camera P5534 as camera input (Hardware Compatibility)
by GPBCTech 5/6/2015 2:15:45 PM(UTC)
What IP Camera is recommended for vmix direct iput (Hardware Compatibility)
by antz 11/13/2014 10:37:39 AM(UTC)
IP camera with audio (Hardware Compatibility)
by antardwip 10/1/2014 5:52:09 PM(UTC)
IP camera with audio (General Discussion)
by antardwip 7/16/2014 5:43:47 PM(UTC)
Axis IP camera problems (General Discussion)
Belarus HWL1223 5/14/2014 6:36:06 PM(UTC)
Should this ip camera address work in stream input? (General Discussion)
by antardwip 4/16/2014 5:13:33 PM(UTC)
Choosing an IP camera that works with vMix (General Discussion)
by antardwip 4/13/2014 10:45:15 AM(UTC)
How to add a ip camera with username/password? (General Discussion)
by wwdv 1/18/2014 3:53:29 PM(UTC)
IP Camera Capture (Feature Requests)
by GeorgeR 12/10/2013 11:24:11 PM(UTC)
ip camera input (Feature Requests)
by TVIason 11/21/2013 12:25:28 PM(UTC)
