display
#1 Posted : Friday, April 28, 2017 11:22:07 AM(UTC)
display
Hi
I would want to configure my IP camera with vMix what is the solution ,
display attached the following image(s):
ip camera.png (130kb) downloaded 4 time(s).
#2 Posted : Friday, April 28, 2017 11:24:44 AM(UTC)
You have been a member since:: 3/20/2014(UTC)
Hi
tell us which camera (model, brand)
bien à toi
Guillaume
display
#3 Posted : Friday, April 28, 2017 11:28:04 AM(UTC)
display
Hi
vision brand China
#4 Posted : Friday, April 28, 2017 11:47:20 AM(UTC)
give us the exact model or product reference or an url so that we can check which camera it is...
Mari
#5 Posted : Friday, April 28, 2017 1:12:13 PM(UTC)
Mari
Netherlands
For my Foscam C2 IP-cams I use the following URL to connect:
rtsp://user:password@ip-adres:88/videoMain
Not all cams are the same, therefore you should check manual or find out on internet using google!
display
#6 Posted : Saturday, April 29, 2017 4:35:16 AM(UTC)
display
Hi
hi this brand for this IP camera AEVISION model AE-2AF1-0402-12V
#7 Posted : Saturday, April 29, 2017 5:25:42 AM(UTC)
Ok so here's the product page by the manufacturer
http://www.aevision.com.cn/product1/show-265.html
I think RTSP is the way to go. Unfortunately there's no documentation online.
From the specs I noticed that audio is G711 Alaw. This is not compatible with vMix, so at best you will have image only or probably nothing at all unless there is a way to deactivate audio from the feed.
Maybe VLC will ingest H264+G711, so it could be possible to NDI out from VLC to vMix.
Sorry I can't help more but without documentation it's difficult. I suppose anyway the web interface for the camera should explain how to use it.
Guillaume
display
#8 Posted : Saturday, April 29, 2017 7:30:16 AM(UTC)
display
thank you Guillaume I contacted the supplier for this topic, I wait for the answer
display
#9 Posted : Tuesday, May 9, 2017 6:18:43 AM(UTC)
display
Hi
I received the rtsp of my supplier the camera is work well
thank you
