Hi I would want to configure my IP camera with vMix what is the solution , display attached the following image(s):  stream.JPG (45kb) downloaded 4 time(s). ip camera.png (130kb) downloaded 4 time(s).You cannot view/download attachments. Try to login or register.
Joined: 3/20/2014(UTC) Posts: 2,721   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
Hi
tell us which camera (model, brand)
bien à toi Guillaume
give us the exact model or product reference or an url so that we can check which camera it is...
Joined: 2/14/2016(UTC) Posts: 118  Location: Oss Thanks: 12 times Was thanked: 15 time(s) in 14 post(s)
For my Foscam C2 IP-cams I use the following URL to connect:
rtsp://user:password@ip-adres:88/videoMain
Not all cams are the same, therefore you should check manual or find out on internet using google!
Hi hi this brand for this IP camera AEVISION model AE-2AF1-0402-12V
Ok so here's the product page by the manufacturer http://www.aevision.com.cn/product1/show-265.htmlI think RTSP is the way to go. Unfortunately there's no documentation online. From the specs I noticed that audio is G711 Alaw. This is not compatible with vMix, so at best you will have image only or probably nothing at all unless there is a way to deactivate audio from the feed. Maybe VLC will ingest H264+G711, so it could be possible to NDI out from VLC to vMix. Sorry I can't help more but without documentation it's difficult. I suppose anyway the web interface for the camera should explain how to use it. Guillaume
thank you Guillaume I contacted the supplier for this topic, I wait for the answer
Hi I received the rtsp of my supplier the camera is work well thank you
