kjones9999
#1 Posted : Sunday, July 1, 2018 11:47:06 PM(UTC)
kjones9999
I like Panamation and NDI Telestrator, but even $200 is hard to find these days in public education. I really wanted to add telestration for football this year. I found a free solution, and while I haven't quite figured out the workflow, I think it will be pretty simple.. The only drawback is there are no shapes, just lines. I may try to add that when I can to the code. The program is called "TransparentPaint"- I found it on github . When executed, the program allows one to draw on a webpage. In vmix, I just added the webpage as an overlay, and use the drawing surface on top of my preview for orientation. It works pretty well. Here is an example of a replay with telestration. Apologies for the quality of the video, I am using vMix basic for this example.
thanks 2 users thanked kjones9999 for this useful post.
AlanZ on 4/9/2021(UTC), R0ll0verRandy on 6/12/2024(UTC)
Similar Topics
Telestrator broken (Beta Discussion)
by WatsonPrunier 11/11/2026 11:10:13 PM(UTC)
telestrator fullscreen escape (Feature Requests)
by Eric Haug 1/20/2026 6:16:02 AM(UTC)
Telestrator API (Feature Requests)
by cgroom 11/12/2025 8:30:54 AM(UTC)
Straight Line and Measured Angles in Telestrator (Feature Requests)
by cgroom 9/30/2025 4:43:06 AM(UTC)
Activators for Telestrator buttons (Feature Requests)
by kricher1964 8/12/2025 10:08:51 PM(UTC)
Telestrator Freeze (Feature Requests)
by mortonc1 7/25/2025 12:38:53 PM(UTC)
Drawing on the screen during a live stream without using the Telestrator (General Discussion)
by Beau Dodson 5/28/2025 12:55:02 AM(UTC)
Telestrator GIFs (Feature Requests)
by chorri 4/25/2025 10:52:34 AM(UTC)
Telestrator Laserpointer with Logitech Spotlight Presenter (Feature Requests)
by robertskiba 4/2/2025 3:58:27 PM(UTC)
Telestrator with clicker option (3rd Party Software and Development)
by vernierj 3/26/2025 8:42:20 PM(UTC)
Telestrator WebRTC Video Only Webpage (Feature Requests)
by ckvideo 3/22/2025 12:09:38 AM(UTC)
Telestrator query string (General Discussion)
by bscav 3/8/2025 7:07:13 PM(UTC)
Telestrator Button to advance slide in propresenter (General Discussion)
by Tim Bartlett 2/24/2025 5:51:09 AM(UTC)
Telestrator In vMix Call (Feature Requests)
by jpink 2/3/2025 3:59:33 AM(UTC)
Request for API Support to Configure Telestrator Line Color and Other Settings via Web API (Feature Requests)
by ken5o 2/1/2025 11:28:21 AM(UTC)
How to Predefine and Select Telestrator Colors in vMix 28? Can It Be Set via Web API? (General Discussion)
by ken5o 1/31/2025 3:24:21 PM(UTC)
telestrator shortcuts (General Discussion)
by jane 1/31/2025 4:17:51 AM(UTC)
Improvements in telestrator (Feature Requests)
by JAIRODJ 1/30/2025 8:00:46 AM(UTC)
Important telestrator changes (Feature Requests)
by JerusalemMediaGroup 1/28/2025 10:18:13 PM(UTC)
Iimportant changes for telestrator (Beta Discussion)
by JerusalemMediaGroup 1/13/2025 8:25:28 PM(UTC)
Telestrator won't show live, won't Erase All, won't show shortcut action. (Beta Discussion)
by sinc747 1/9/2025 3:22:46 AM(UTC)
Telestrator select and lock pointer (Feature Requests)
by nikosman88 12/13/2024 9:34:13 AM(UTC)
Telestrator check if on HTTPS (FIXED) (Beta Discussion)
by Unieveth 11/22/2024 8:35:56 PM(UTC)
Assigning of shortcut buttons for Telestrator (solved) (Beta Discussion)
by JakeyBoyPro 11/7/2024 9:12:00 PM(UTC)
Add basic text titler to the telestrator (Feature Requests)
by WaltG12 9/14/2024 4:27:34 AM(UTC)
Telestrator with vMix Replay (3rd Party Software and Development)
by MikeBenke 10/4/2018 2:33:26 AM(UTC)
NewTek NDI Telestrator used with VMix (NDI)
by BentRS 5/2/2018 1:29:30 PM(UTC)
NewTek NDI Telestrator (NDI)
by richardgatarski 5/11/2016 2:43:01 PM(UTC)
Separate Telestrator System using Flash (General Discussion)
by tesn 1/21/2016 10:52:20 AM(UTC)
vMix Telestrator Plugin (General Discussion)
by Thremir 9/12/2014 4:36:33 PM(UTC)
