sinc747
#1 Posted : Thursday, January 9, 2025 3:22:46 AM(UTC)
sinc747
Was thanked: 201 time(s) in 167 post(s)
Telestrator mostly unresponsive on remote PC. I can draw a line and it shows in the Telestrator on the remote PC, but Erase All does not erase on remote PC. Does erase in vMix. I can click the shortcut PlayPause in Telestrator on the remote PC and it does not show the Play or Pause on the remote PC. vMix PC shows to executed shortcut. Other shortcuts on Telestrator work on vMix PC but not remote PC. Is this a network issue? Only vMix PC, NDI/HX camera and remote PC are on the network.
Version 28.0.0.27 on Windows 10 Pro, i9-10900KF, 16GB RAM, 4070 ti (driver 566.36). Using a video clip assigned as Output 2 and Output 2 assigned as Telestrator source. Telestrator web controller running on Surface Pro 6 (WIFI). No other programs running on Surface except Chrome window with Telestrator. Three shortcuts for Telestrator - Cut, Play/Pause (video input), and Restart (video input). Telestrator Latency set to Normal. Telestrator color set to Red.
Thanks for your input.
- Tom
#2 Posted : Thursday, January 9, 2025 12:34:24 PM(UTC)
Was thanked: 4485 time(s) in 1564 post(s)
Hi Tom,
It sounds like a strange browser issue specific to that surface, can you try another WiFi connected device such as a phone at the same time to see if the results are different?
One thing you can also test is the other tabs of the web controller, as the shortcut buttons on the Telestrator use the exact same commands as the normal Shortcuts tab.
sinc747 on 1/11/2025(UTC)
sinc747
#3 Posted : Saturday, January 11, 2025 8:09:23 AM(UTC)
sinc747
Thank you, Martin.
Seems to work okay with my iPhone.
I reduced the Video Quality (on Web Controller Settings window) from 2mbps to 1mbps. Noticeable reduction in resolution of the image sent to the Surface (of course) and it seemed to help for a moment or two. But then it appears that a buffer filled up and then froze the image on the Surface.
Shortcuts on the Telestrator window on the Surface worked in vMix but did not appear on the Surface screen (cut, stop/start, restart).
All vMix related activities continued with no issues. The only issue is with the Chrome browser on my Surface.
What else can I test?
- Tom
#4 Posted : Monday, January 13, 2025 4:41:44 PM(UTC)
Sounds like a WiFi issue.
That said, we've just released an update (28.0.0.31) which should be more resilient in bad wifi conditions, but still not perfect (as we can only do so much).
Give it a try.
sinc747 on 1/14/2025(UTC)
sinc747
#5 Posted : Tuesday, January 14, 2025 8:07:08 AM(UTC)
sinc747
Martin,
Thanks for your input and new version 28.0.0.31. I updated to the new version just now.
But about three hours ago I updated the BIOS and drivers on my Surface Pro 6. (It's End of Life but BIOS and drivers from 2023 are available). As a habit I force my Windows updates frequently but the package I downloaded and installed must have included some I didn't have.
So, I made two changes at once.
Version 28.0.0.31 worked with my updated Surface at 1mbps. 2mbps had some delays but the Telestrator video would catchup when I paused the video source on the PC Using a Telestrator shortcut. I love those shortcuts!
Since I wasn't sure which change actually worked for me, I reinstalled 28.0.0.27 and tested it with the same preset. I got the same positive result as I did with 28.0.0.31. So the problem was with my hardware.
- Tom
Guest (4)
