nikosman88
#1 Posted : Friday, December 13, 2024 9:34:13 AM(UTC)
nikosman88
Greece
Was thanked: 97 time(s) in 93 post(s)
Hello. Telestrator is a very usefull function and thanks for that. For feature request i would like to be able to select and lock pointer so the user of telestrator cannot be able to select any other function that telestrator has.The drawing button on/off also disables the pointer.
Why this? Because some of my talents studio that are going to use this function,are not very good with technology and for example i select the laser function and then they change it by mistake and panic on how to return in previous function. This is not the best scenario in a live show when the talent believes that he will point in the image,but he draw lines here and there...
Thank you
