Coet
#1 Posted : Thursday, June 14, 2018 12:22:34 PM(UTC)
Coet
I use a pc basic program to play MIDI songs. How can I import those audio songs into vmix.
Thanks todd
#2 Posted : Friday, June 15, 2018 12:47:41 PM(UTC)
Are you talking about playing your midi sequences live into vMix ? Do you need a live control on the midi playout ?
If no : just record your midi sequences as wav files and import them in to vMix.
If yes : there are many solutions depending on what midi software/synthesizers you use and how your audio device(s) is/are setup in Windows.
Basically the point to set the audio OUT from your midi to an audio interface that plays the sound. Then simply add this audio interface into vMix as an audio input.
It might get a little complex if you only have a single audio interface to do it all. As the case may be, just use a Virtual Cable to patch things directly.
THere's been a lot of talk about Virtual Cables in this forum, use the search function to find them and learn how it works and where to download them
Hope this helps
Guillaume
Similar Topics
MIDI Joystick sensitivity (General Discussion)
by DThompson55 6/23/2026 10:12:49 AM(UTC)
Midi Controller - Donner StarryCtrl (Hardware Compatibility)
by smaney 5/27/2026 3:16:38 PM(UTC)
Resize layers from MIDI control (General Discussion)
by 3579865 2/16/2026 11:04:21 AM(UTC)
Dynamic MIDI Fader Logic (General Discussion)
by bjurrenswho 1/30/2026 1:30:55 AM(UTC)
Configuration for MIDI inputs (General Discussion)
by Markmumc 12/9/2025 5:48:45 AM(UTC)
Flic.io button as midi button for vmix (General Discussion)
by ArnoudMol 6/5/2025 8:05:29 AM(UTC)
TYST 1500HD - midi channel problem (General Discussion)
by tomice 1/27/2025 7:44:35 PM(UTC)
Shortcuts for Midi to control of all/any sliders (Feature Requests)
by vjmandala 11/14/2024 11:46:06 AM(UTC)
Endless rotary MIDI (Instant Replay)
by gefiltafish 9/26/2024 11:03:19 PM(UTC)
T-Bar roll replay with MIDI Controller does not work (Instant Replay)
by furtive 8/28/2024 9:42:07 AM(UTC)
strange midi piano sounds in vmix (Hardware Compatibility)
by V-G 2/20/2024 5:36:42 PM(UTC)
Send Midi CC Message (General Discussion)
by Sev 8/16/2023 6:29:31 AM(UTC)
Send a VMix midi cc message to start a song in another program (General Discussion)
by Sev 8/9/2023 2:38:54 PM(UTC)
Insta360 - PTZ - Midi Map - Pan X,Y. ZOOM - AKAI APC Mini (General Discussion)
by live 3/17/2023 1:21:51 PM(UTC)
Rodecaster PRO II MIDI (Hardware Compatibility)
by roverradio 1/9/2023 9:03:45 AM(UTC)
Scripting .net - Get button / Joystick / Midi values? (3rd Party Software and Development)
by Tuomas 1/6/2023 8:55:29 PM(UTC)
Support for MIDI events to be received/sent to/from VST plugins (Feature Requests)
by engelschall 8/27/2022 7:11:30 AM(UTC)
How to setup audio for vmix with MIDI device (General Discussion)
by pzj6211 8/8/2022 6:52:31 PM(UTC)
Special Waves MIDI (Hardware Compatibility)
by gefiltafish 6/2/2022 11:44:31 PM(UTC)
RODECaster MIDI Activators (General Discussion)
by roverradio 4/20/2022 2:20:53 AM(UTC)
MIDI T-bar Fader Issue (Hardware Compatibility)
by JxM 4/8/2022 11:11:00 PM(UTC)
change preset / title editor / midi /shortcut (General Discussion)
by paulpfab 2/9/2022 10:48:13 PM(UTC)
MIDI Input in Script VB.NET (3rd Party Software and Development)
by Hanz_Brech 1/22/2022 3:28:54 AM(UTC)
Midi Solutions R8 as TALLY (Hardware Compatibility)
by Harpert 1/10/2022 7:34:38 PM(UTC)
use vMix to control other MIDI devices on the network (Feature Requests)
by rodb 12/15/2021 11:20:23 AM(UTC)
SetFade in/out to a midi button (General Discussion)
by Chumbaz 12/10/2021 10:05:18 PM(UTC)
MIDI shortcut to activate other shortcuts? (General Discussion)
by lepkirk 8/11/2021 2:08:33 AM(UTC)
Shortcut Select Registered Replay Tags in Midi Controller without mouse and Keyboard (Feature Requests)
by WesleyFernandes 8/6/2021 12:17:51 AM(UTC)
Shortcut Instant Replay Select events with midi controller without mouse and keyboard (Feature Requests)
by WesleyFernandes 8/6/2021 12:13:29 AM(UTC)
Suport for sub zero midi controller (Feature Requests)
by stefan svanstrom 7/30/2021 11:10:19 AM(UTC)
