TYST 1500HD - midi channel problem
Joined: 12/20/2021(UTC) Posts: 4  Location: Sierakowice
I was using panel few years with success, but some time ago sth wrong was happend.
PVW, PGM, DSK buttons changed midi channel to 2, it looks like permanently Shift used. When I push SHIFT it goes to channel 3.
Same problem is with Faders - they changed also to channel 2 and f.e. in CentralControl they are not visible in TYST, but Generic MIDI see them.
Do you have any idea what can be problem?
It would be enough for me to edit TYST in Central Control - is it possible?
Joined: 3/30/2023(UTC) Posts: 126  Location: Chicago Thanks: 11 times Was thanked: 6 time(s) in 5 post(s)
Both versions of TYST1500 are supported in Central Control.
