Joined: 5/6/2016(UTC) Posts: 83  Was thanked: 5 time(s) in 5 post(s)
RODEcaster Pro allows the 8 buttons on the pad to be used for MIDI triggers, which is great for setting up vMix shortcuts to do simple camera switching in a roadkit. The buttons are backlit, and when used for sound they light up when a sound is played, etc.
My issue is I'd like to be able to set Activators for a button to light up when the camera associated with a shortcut is live. Haven't been able to make it work (rodecaster is enabled as a MIDI/activator device, but it doesn't appear in the dropdown in the Activator setup window).
Is this possible to do? Thanks!
