lem
#1 Posted : Wednesday, June 21, 2017 3:28:40 AM(UTC)
lem
I used the VMIX NDI transmission signal, found in more than 10 minutes, the video every few seconds there will be 1-2 seconds interval?
I do not know why
1 I am using vMix Desktop Capture for NDI
Settings: 60fps audio: loopback
I7 6700T CPU@2.80Ghz, 8GB X64, NVIDIA GeForce GTX 960
2 vmix NDI reads the NDI signal
3 vmix recording NDI signal (OBS recording I tried, the same effect)
4 I was using the 1000M switch (1G I also tried)
Can NDI set frame rate and bit rate?
#2 Posted : Friday, June 23, 2017 11:53:51 AM(UTC)
Hi
No
But you say "1000M switch (1G I also tried)" ???
1000Mbits is the same as 1 Gbits. Maybe you are confusing with 100Mbits?
Make sure to use a 1Gbits switch, with gigabit ethernet interfaces on all your computers AND at least CAT5e cables. CAT6 is better.
Guillaume
lem
#3 Posted : Friday, June 23, 2017 12:02:46 PM(UTC)
lem
Thank you very much for your reply! That sentence is my expression wrong!
#4 Posted : Friday, June 23, 2017 12:17:02 PM(UTC)
Do you still have the problem ?
lem
#5 Posted : Friday, June 23, 2017 12:20:42 PM(UTC)
lem
Why do I play Caton when recording, or intermittent pause? After a few seconds, the recorded video will automatically pause for 1 second.
Similar Topics
VMix NDI receive issues. (NDI)
by vjmandala 5/28/2024 12:14:41 PM(UTC)
NDI Excessive Source Drops from vMix NDI Source only (NDI)
by Maximus 2/2/2024 4:53:11 AM(UTC)
vMix NDI output bandwidth. (General Discussion)
by g7pfv 1/13/2023 7:10:46 AM(UTC)
Vmix ndi caputre M1 can't install soundflower to get audio (NDI)
by openaspace 1/1/2023 10:18:06 PM(UTC)
Vmix NDI Config (NDI)
by P4lma 3/19/2022 8:38:07 PM(UTC)
vMix NDI stuttering and lagging receiving in vMix (NDI)
by bruzehual 10/8/2021 7:42:53 PM(UTC)
Issues with 15+ devices receiving vMix NDI output (NDI)
by Andrew 3/2/2021 6:54:31 AM(UTC)
vMix NDI x DANTE Router Tool (Feature Requests)
by Paul_WCP 9/13/2020 4:20:54 AM(UTC)
VMix NDI Audio pops and clicks on Zoom (NDI)
by Ezzra 7/17/2020 6:35:14 PM(UTC)
Audio Dropouts on vMix-to-vMix NDI Sources (NDI)
by Geoff B 7/1/2020 1:27:50 PM(UTC)
Windows 10 and Vmix ndi capture problem (NDI)
by Haone1234 1/22/2020 2:32:23 PM(UTC)
vMix NDI output and Multicast (NDI)
by Non Grata 12/6/2018 2:48:32 AM(UTC)
Latency of VMIX NDI inputs (NDI)
by JoseL 11/5/2018 11:13:58 PM(UTC)
vMix NDI only works if Admin User (NDI)
by roverradio 6/26/2018 9:59:25 PM(UTC)
vMix NDI Desktop Capture has stopped running (NDI)
by BigRev 1/15/2017 9:01:01 PM(UTC)
vMix NDI Desktop Capture Error (NDI)
by computerman1597 5/15/2016 1:22:22 PM(UTC)
