I used the VMIX NDI transmission signal, found in more than 10 minutes, the video every few seconds there will be 1-2 seconds interval? I do not know why 1 I am using vMix Desktop Capture for NDI Settings: 60fps audio: loopback I7 6700T CPU@2.80Ghz, 8GB X64, NVIDIA GeForce GTX 960
2 vmix NDI reads the NDI signal 3 vmix recording NDI signal (OBS recording I tried, the same effect) 4 I was using the 1000M switch (1G I also tried)
Can NDI set frame rate and bit rate?
Joined: 3/20/2014(UTC) Posts: 2,721   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
Hi Quote: Can NDI set frame rate and bit rate?
No But you say "1000M switch (1G I also tried)" ??? 1000Mbits is the same as 1 Gbits. Maybe you are confusing with 100Mbits? Make sure to use a 1Gbits switch, with gigabit ethernet interfaces on all your computers AND at least CAT5e cables. CAT6 is better. Guillaume
Thank you very much for your reply! That sentence is my expression wrong!
Do you still have the problem ?
Why do I play Caton when recording, or intermittent pause? After a few seconds, the recorded video will automatically pause for 1 second.
