lem
#1 Posted : 8 years ago
lem
I used the VMIX NDI transmission signal, found in more than 10 minutes, the video every few seconds there will be 1-2 seconds interval?
I do not know why
1 I am using vMix Desktop Capture for NDI
Settings: 60fps audio: loopback
I7 6700T CPU@2.80Ghz, 8GB X64, NVIDIA GeForce GTX 960
2 vmix NDI reads the NDI signal
3 vmix recording NDI signal (OBS recording I tried, the same effect)
4 I was using the 1000M switch (1G I also tried)
Can NDI set frame rate and bit rate?
#2 Posted : 8 years ago
Was thanked: 794 time(s) in 589 post(s)
Hi
No
But you say "1000M switch (1G I also tried)" ???
1000Mbits is the same as 1 Gbits. Maybe you are confusing with 100Mbits?
Make sure to use a 1Gbits switch, with gigabit ethernet interfaces on all your computers AND at least CAT5e cables. CAT6 is better.
Guillaume
lem
#3 Posted : 8 years ago
lem
Thank you very much for your reply! That sentence is my expression wrong!
#4 Posted : 8 years ago
Do you still have the problem ?
lem
#5 Posted : 8 years ago
lem
Why do I play Caton when recording, or intermittent pause? After a few seconds, the recorded video will automatically pause for 1 second.
Similar Topics
VMix NDI receive issues. (NDI)
by vjmandala 12 months ago
NDI Excessive Source Drops from vMix NDI Source only (NDI)
by Maximus about a year ago
vMix NDI output bandwidth. (General Discussion)
by g7pfv 2 years ago
Vmix ndi caputre M1 can't install soundflower to get audio (NDI)
by openaspace 2 years ago
Vmix NDI Config (NDI)
by P4lma 3 years ago
vMix NDI stuttering and lagging receiving in vMix (NDI)
by bruzehual 4 years ago
Issues with 15+ devices receiving vMix NDI output (NDI)
by Andrew 4 years ago
vMix NDI x DANTE Router Tool (Feature Requests)
by Paul_WCP 5 years ago
VMix NDI Audio pops and clicks on Zoom (NDI)
by Ezzra 5 years ago
Audio Dropouts on vMix-to-vMix NDI Sources (NDI)
by Geoff B 5 years ago
Windows 10 and Vmix ndi capture problem (NDI)
by Haone1234 5 years ago
vMix NDI output and Multicast (NDI)
by Non Grata 6 years ago
Latency of VMIX NDI inputs (NDI)
by JoseL 7 years ago
vMix NDI only works if Admin User (NDI)
by roverradio 7 years ago
vMix NDI Desktop Capture has stopped running (NDI)
by BigRev 8 years ago
vMix NDI Desktop Capture Error (NDI)
by computerman1597 9 years ago
